Old 01-08-2011, 05:41 PM   #1
72MARIO
72MARIO's Avatar
Bags in place of coils ? 68 Burban. What Bags
I see that ECE sells a air ride kit for trucks and burbs. I would like to put somthing like this in place of the rear coils. So I roll low and still tow a car trailer. I dont think I am going to notch it because I am worried about the strength.............. just put in a 1/2 bump stop on the frame.
I see that Air lift has a small compressor kit looks neat and small would it work oky ?
So what bags should I use besides the ECE kit ?
Panhard bar ?
I have looked at the KP kit with the notch and truck arm kit it looks really neat but would it still be as strong as a Factory frame ? I would love to go this route but I need to be able to tow.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-08-2011, 05:43 PM   #2
72MARIO
72MARIO's Avatar
Re: Bags in place of coils ? 68 Burban. What Bags
the burb
2005 TAHOE DD
Old 01-08-2011, 05:53 PM   #3
PBFAB.COM
PBFAB.COM's Avatar
Once you swap over from coils to bags, I would recommend a trac-bar upgrade as well.
Are you planning on doing the front as well? or just the rear at this time?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-08-2011, 05:58 PM   #4
72MARIO
72MARIO's Avatar
I will do the front in time. I need to sell my 67 short box first.
2005 TAHOE DD
Old 01-08-2011, 06:05 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
If you plan on doing the front at a later date, then you may want to hold off on an air management (compressor, valves, tank, etc.). You can run the rear on a schrader system that can be inflated with a shop compressor when it's time to tow, and left at "just the right height" when you're not.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-08-2011, 06:09 PM   #6
72MARIO
72MARIO's Avatar
do you know with the ece kit can i roll with it about a 5" drop and still have it ride nice ? are there any better options ?
2005 TAHOE DD
Old 01-09-2011, 07:41 PM   #7
sixtyeightchevykid
sixtyeightchevykid's Avatar
im thinking about doing the same with my 68 lwb, but im lost so any help would be good...
sixtyeightchevykid is offline   Reply With Quote
Old 01-10-2011, 12:49 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
I would start with a 2600# bag of your choice. Slam Specialties RE7s are good stuff, as are Dominators and Firestones, but there are tons of choices out there.
There is a write-up in FAQ about how to convert from coils to bags without using any of the fancy, unnecessary mounting bracketry found in the aftermarket 'kits'.
The bolt-in notches have been found to be plenty strong for towing, especially if welded in for insurance. Many people on the board have done it, myself included. A button bump-stop would probably be sufficient at only 5" drop though.
Full length panhard bar, ala ECE or CPP will suit your needs, and are adjustable.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-10-2011, 03:14 PM   #9
sixtyeightchevykid
i dont want to seen like a dumb kid, but i cant seem to find the write-up... could i get a link?
Old 01-10-2011, 03:20 PM   #10
jimmydean
jimmydean's Avatar
Don't feel bad, I couldn't either.
I know there are a lot of great write ups on here because I used one last time.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-10-2011, 03:31 PM   #11
sixtyeightchevykid
alright ill try not to feel too bad ha, yes this site is a really great site lots of good info. lol i guess sometimes you just need to be smarter than the internet. and i guess im not
Old 01-10-2011, 04:15 PM   #12
SCOTI
SCOTI's Avatar
Forums screen >info center > FAQ's. Site related or truck tech are your 2 choices....
http://67-72chevytrucks.com/vboard/f...splay.php?f=28
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-10-2011, 04:45 PM   #13
jimmydean
jimmydean's Avatar
And my intelligence is again questioned because I don't see a coil to bags thread in the Suspension and Steering FAQ section.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-10-2011, 05:17 PM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
Here's a few air bag tech articles.
Plus a few other suspension articles of interest.
I'll add more when I find them.
RideTech
http://www.ridetech.com/pdfinstructi...s/ARF11800.pdf
http://www.ridetech.com/pdfinstructi...s/ARR21800.pdf
CPP
Modular spindles:
http://www.classicperform.com/tech_a....06.09-web.pdf
Tubular control arms:
http://www.classicperform.com/tech_a...bular_Arms.htm
http://www.classicperform.com/tech_a...r-Part-One.htm
http://www.classicperform.com/tech_a...r-Part-Two.htm
http://www.classicperform.com/tech_a...Part-Three.htm
Sway bar with air bags:
http://www.classicperform.com/tech_a.../InControl.htm
Air suspension:
http://www.classicperform.com/tech_a...ow/Sub-Low.htm
Bolt-In C-Notch Install:
http://www.classicperform.com/tech_a...ch/c-notch.htm
67-70 Drum to Disc Conversion:
http://www.classicperform.com/discdrop.htm
Rear Lowering Coil Spring trucks:
http://www.classicperform.com/goingdown6772.htm
ECE:
Rear:
http://www.earlyclassic.com/tech.asp...20Grand%20Slam
Drum to disc:
http://www.earlyclassic.com/tech.asp...arly%20Braking
6-Lud Disc:
http://www.earlyclassic.com/tech.asp...h%20And%20Whoa
Rear Air Bags:
http://www.earlyclassic.com/tech.asp...0Get%20Rolling
Keith
Convert to disc brakes.
Old 01-10-2011, 06:02 PM   #15
jimmydean
jimmydean's Avatar
That is an awesome list, and yet not a single thread from here.
My comment was more to the point that there are many great build threads with pictures that I used to be able to find but somehow can't and none of them are in the FAQ section. Hell, gringoloco's dropmember build was one that I can't find now.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-10-2011, 07:33 PM   #16
lolife99
lolife99's Avatar
Sorry,... I was trying to satisfy you guys until I got home.
I couldn't find the FAQ "coils to bags" specific article.
I don't even remember one.
I did my search on the internet in about 5 minutes with DSL at work.
I have dial-up at home.
So I won't be much help.
There are a bunch of member that want these threads.
I'll do some looking,... but you guys have to help me.
Better yet,... do a tech article of your own,...when you bag your own trucks.
See how much of a PITA that is.
That's why I commend people like Rokcrln,... that has the patience to do what he does.
I'll keep looking on here.
But the internet and Google is a great source also.
Keith
Old 01-10-2011, 07:36 PM   #17
lolife99
lolife99's Avatar
Panhard bar ?
I like using a RE-7 or SS-7 Slam Specialties bag,... bolted directly in place of the coil spring.
Use a 3/8"x4" bolt with a HD washer thru the trailing arm.
Drill 2 mounting holes and 1 large air fitting hole in the frame, to mount the upper end of the bag.
Run two lines with two schraders for the time being.
Keith
Old 01-10-2011, 07:52 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
Found it! It was under Krue's index thread...
MrShelley's guide shows the basics. Feel free to ask any questions you might still have after reading through it. I have done three trucks, my '70 and two friends '65-'66s, exactly like this with excellent results.
http://67-72chevytrucks.com/vboard/s...d.php?t=129463
-Chris
Old 01-10-2011, 07:56 PM   #19
lolife99
lolife99's Avatar
Thanks Gringoloco^^^.
Keith
Old 01-10-2011, 08:02 PM   #20
gringoloco
A guy with a truck
gringoloco's Avatar
Good advice here. Crank snout/harmonic balancer washers work well for the long 3/8 bolts.
You can also use a cheap in-line ball valve so that you only have one schrader. Open when filling, so that the truck is level, then close to prevent side-to-side transfer, extreme body roll, and scary handling.
-Chris
Old 01-10-2011, 08:40 PM   #21
SCOTI
SCOTI's Avatar
How did you find it?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-10-2011, 08:54 PM   #22
tech@scottshotrods
we are doing slams SS7s under 75.00 with free shipping bracket kit for 70.00 (all four upper and lowers and have lines and fittings
tech@scottshotrods is offline   Reply With Quote
Old 01-10-2011, 11:08 PM   #23
gringoloco
A guy with a truck
gringoloco's Avatar
Little bit of memory work, but basically-
FAQ Forum : Krue's Index Thread : Suspension Section
-Chris
Old 01-11-2011, 12:46 AM   #24
72MARIO
72MARIO's Avatar
Ok I see alot of diffirent bags out here. The ones the erly classics show are huge. What is a RE7 vs SS7. The bags look to basically bolt in. but what ones ?
I am going to need a super track bar kit. Is there a better option ?
SCOTI will your shock mount mod work here with some shorter shocks ?
The air line are pretty easy I undestand all that for now.
2005 TAHOE DD
Old 01-11-2011, 01:54 AM   #25
SCOTI
SCOTI's Avatar
Yes. Prob won't even need shorter shocks, just OE replacement length.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
