Old 01-23-2011, 12:10 PM   #1
burbluv
burbluv's Avatar
Need help with 62 1/2 ton 4x4 burb brakes
Hey everyone,
I just got a 62 with a 350 engine. Running great but stopping is horrible. Using all my leg strength to get it to stop. Very hard brakes and I feel like Fred Flintstone. Brakes were recently rebuilt but something is off. Took it to shop and they said everything seems good but I may need new drums and they need to double check the fit on the pads. I even considered going from drums to disc but since it is 4x4 4spd the parts are not really out there. Even Brothers could not help. They suggested looking into some NAPCO stuff online which is not in my budget. I am looking for either a place to get some new drums, pads and master cylinder or a conversion suggestion that won't kill my pocket.
Thanks so much!
AJ
burbluv is offline   Reply With Quote
Old 01-23-2011, 11:32 PM   #2
burbluv
burbluv's Avatar
Re: Need help with 62 1/2 ton 4x4 burb brakes
TTT
Anyone with some suggestions? Monday is rolling around tomorrow and I really want to get some stuff ordered.
Here are a few shots or my burb.
Anyone? Anyone? Bueller? Bueller?
Old 01-24-2011, 12:02 AM   #3
j.kirn
You should be able to get every thing at your local auto parts store
j.kirn is offline   Reply With Quote
Old 01-24-2011, 12:12 AM   #4
chisler
chisler's Avatar
First off nice looking rig you got there.....sounds like your brakes may be out of adjustment...this sometimes can be cured by backing up and hitting the brakes hard...the back brakes should be self adjusting....second does the emergency brake work....if you put in on a few clicks and drive do you notice any change in the braking if so that would for sure tell me its an adjustment on the brakes....also how is the brake pedal ....is it going to the floor... can you lock up the brakes off roading also...a few thing to try out before spending some money...still a very nice looking rig
chisler is offline   Reply With Quote
Old 01-24-2011, 12:22 AM   #5
burbluv
burbluv's Avatar
Just a confirmation I do not have anything NAPCO on here but since it is a 4X4 stick no one seems to have the right drums. The brakes do not go to the floor it hey are just really stiff and taking a long time to brake and it only happens by my own power. And the emergency brake works. I was also told there is a difference in the pads as well some 2 inch and some 2 and a half. I will try and run out and through it into reverse with a brake stomp.
Old 01-24-2011, 12:03 AM   #6
zac
zac's Avatar
That's NAPCO stuff, right? I never have understood why burbs were still NAPCO but pickups started using GM stuff in '60. My '61 is d44/12bolt/sm420/t221. You're going to need NAPCO experts on this, and I don't know how many are out there. IMHO it would be a damn shame to "convert" anything that is original NAPCO. That stuff is just rare and expensive as far as I know. It's a very cool burb, good luck with it. I'll bet the fix is easy, just may take some time and patience.
zac is offline   Reply With Quote
Old 01-24-2011, 12:06 AM   #7
j.kirn
Nothing on his burb is napco
Old 01-24-2011, 12:07 AM   #8
j.kirn
The 1 ton burbs had napco conversion
Old 01-24-2011, 12:27 AM   #9
zac
zac's Avatar
OK, that explains alot. At a truck show a few years ago I spent over an hour trying to figure out why this huge mid 60's burb had NAPCO stuff....
Old 01-24-2011, 12:31 AM   #10
j.kirn
Lmc has the brake drums , napa, carquest
Old 01-24-2011, 12:40 AM   #11
burbluv
burbluv's Avatar
Thanks j.kirn not sure how I missed it at Napa but what is Lmc?
Thanks and thanks for the props on the truck.
Old 01-24-2011, 12:44 AM   #12
j.kirn
LONG MOTOR CORPORATION aftermarket parts go online and lookup they will send you a free catalog but i would try to get brake drums and pads if you in fact need them from your local autoparts store
Old 01-24-2011, 12:48 AM   #13
burbluv
burbluv's Avatar
7 miles away! Thanks again for the support. Man I loe technology being able to pull all this knowledge and cool **** together!
Old 01-24-2011, 12:56 AM   #14
j.kirn
Good luck on the brakes and dont let anyone tell you to upgrade on the axles these trucks,suburbans are becoming rare with the original drivetrain
Old 01-24-2011, 01:35 AM   #15
75gmc454
75gmc454's Avatar
Check the flexible rubber lines first. They are bad about collapsing. They look good on the outside but the inside breaks down from prolonged exposure to the brake fluid. That blocks the flow of fluid.
75gmc454 is offline   Reply With Quote
Old 01-24-2011, 10:19 PM   #16
burbluv
burbluv's Avatar
J.Kirn is the man! Before I went out and bought anything today and did what you said and threw it into reverse twice and slammed on the brakes and presto! I have brakes! What is your address so I can send you the money I would have blown on new drums and pads!
Thanks again,
AJ
1962, 4x4, burbluv, suburban
