Old 01-30-2011, 03:49 PM   #1
csb#356
double transfer cases
I'm thinking about making a 205/203 double setup because A 203 can be had around here for about 25 bucks. (literally, I couldn't give mine away) And I'm Thinking that not only will i get lower gears but wouldn't it also give me higher gears for the highway? Does anyone have one of these setups and do you like them, And do they bring the rpms down on the highway quite a bit? I'm just looking basically for anyone that has one to tell me what you think of it Please. Much appreciated.
csb#356 is offline   Reply With Quote
Old 01-30-2011, 04:40 PM   #2
OldCreek
OldCreek's Avatar
Re: double transfer cases
I'm pretty sure you will not get higher highway gears. I think the adapters to mate these are fairly expensive so make sure you "need" this setup.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-30-2011, 05:04 PM   #3
csb#356
Ok I just thought since when you put them both in lower it doubles the ratio so the same would go for both in high? And maybe bring the rpms down a bit. Of course I don't need this setup but I'm bored with a tax return and wanna build something. lol. I also just remembered finding a 203 with a 10 spline input shaft would be kinda tricky.
Old 01-30-2011, 05:35 PM   #4
Plunkett
Running a doubler is mainly for offroading reasons. It gives you a lower crawling ratio. It's not going to cut down on the rpms in your truck while driving around town.
1987 gmc sierra v1500. 350 tbi, 700r4, 6" sky jacker lift, 15" Mickey Thompson wheels, and 35" bf Goodrich km2 tires.
Plunkett is offline   Reply With Quote
Old 01-30-2011, 05:50 PM   #5
63chevyll
gets board easy.......
63chevyll's Avatar
i want to do if but dont have the $$ for adaptor and $$ for shafts at this time and i think there is some $$ for shifters and some $$ and time for crossmember modification
63chevyll is offline   Reply With Quote
Old 01-30-2011, 06:12 PM   #6
csb#356
I know its mainly for offroad which I do quite a bit of. Does anyone have one of these?
Old 01-30-2011, 06:15 PM   #7
Plunkett
If you want to get some really good info, go to ck5.com or pirate4x4.com. Both of those sites will have all of the info that you want/need for putting a doubler in your 4x4. Also, Off road design sells all the parts required to install one in our trucks.
Old 01-30-2011, 07:27 PM   #8
csb#356
Ok thanks for the link
Old 01-30-2011, 09:12 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes, I believe high range is direct 1:1 ratio in both. Double cases gives more gear reduction in low-low but nothing above 1:1 in high.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 01-30-2011, 10:42 PM   #10
MTCK
MTCK's Avatar
Stocker is right. 1:1 and 1:1 is still.... 1:1. In low you will have 2:1 reduction (205 only) and 4:1 (203 range box and 205 in low). Big bucks. I'd love one. www.offroaddesign.com has lots of info. As mentioned, drive shafts, cross members, shifters, likely exhaust work...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-30-2011, 11:14 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
For your theory to be correct one of the cases would basically have to have an "overdrive" set of gears in it. So, you would have to be able to put in one rotation and get out 1.3 rotations (just an example). That's basically what OD is in an overdrive transmission. On the other hand the transfer cases you mentioned when shifted into 4 low will divide the input rotations as opposed to multiplying them aka "underdriven". In other words if you put in 1 rotation the output will only turn .5 of a rotation. So when people create a doubler they take the 2:1 of the 203 and bolt it to the 2:1 drive of the 205 giving you a 4:1 crawl (2x2 not 2+2). Hope this helps.
Also, look here
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-31-2011, 04:06 PM   #12
csb#356
Yeah I looked on ORDs website and there is way more things that I didn't Think about. I have a couple 203s and 205s but none are the correct ones, and quite a bit more modification would be necessary and more exspensive than i thought. Still would be cool to have one though
Old 01-31-2011, 04:23 PM   #13
royo
royo's Avatar
North west fab I think is the name of it , they have more options for a doubler.10. 27 spline.
nickle and dime
royo is offline   Reply With Quote
Old 01-31-2011, 04:43 PM   #14
csb#356
Thanks royo i'll Check them out
Old 02-01-2011, 04:35 AM   #15
1malo68
1malo68's Avatar
I bought my working Warn 8274 winch for $400.00 from this guy about 6 months ago and he had this setup at that time. He's been trying to sell it on CL for a long time now. You might be able to get it for a better price. I've seen it and it is what he says it is. Good honest guy. He's in Vegas. might be worth a call. FWIW
http://lasvegas.craigslist.org/pts/2157712852.html
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 02-01-2011, 02:00 PM   #16
csb#356
Thanks I'll check it out and see if maybe he'll seperate it
