Old 02-22-2011, 03:31 AM   #1
J/D/S
79 Fuel tank questions
What gallon capacity fuel tanks came on a dual fuel tank truck? Also whats the biggest dual tanks I can put on a 79 in the stock locations. Changing out the tanks location is not an option.
thanks guys
John Bernard Books (The Shootist):
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them."
J/D/S is offline   Reply With Quote
Old 02-22-2011, 08:52 AM   #2
madcow75
madcow75's Avatar
Re: 79 Fuel tank questions
They only made 2 different size saddle tanks 16 and 20 gallon tanks. I am sure if you allready have dual tanks you have the 20 gallon tanks. 20 gallon tanks were put on longbeds and 16 on shotbeds. 16 gallon measuring 42 1/4" long and 20 gallong measuring 56" long.
madcow75 is offline   Reply With Quote
Old 02-22-2011, 03:06 PM   #3
willstruck
According to LMC, some longbeds actually had 16 gallon tanks, not sure the years. But, my 85 longbed has dual 16 gallon tanks. One leaks, so a single 16 gallon tank on a truck that gets 12mpg really sucks. I bet if you search, you can find a company that makes larger tanks that fit in the stock location. The tanks are so straightforward, I might just make new tanks. I can do it for cheaper than a stock replacement would cost.
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
Old 02-22-2011, 04:18 PM   #4
Benelli
Watchin the rust grow
Benelli's Avatar
You can swap over to Blazer or Suburban tanks and I believe them hold as much as 32 or 36 gallons.
I think you can also rig up some mounts and staps to use the 89-98 tanks.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 02-22-2011, 05:41 PM   #5
madcow75
madcow75's Avatar
Suburban tanks are 25, 31, and 40 gallon. 25 and a 31 gallon fit in a truck but you need to modify to fit it behind rear axle between frame rails.
