Old 03-24-2011, 08:25 AM   #1
Patsfan34
Patsfan34's Avatar
Suggestions on body mount/cab mount kit?
I'm almost at the point of mounting the body and getting this truck to paint before final assembly. Any and all suggestions welcome. Should I go rubber, should I go poly? Why, which manufacturer? My frame is a 68 GMC 4x4 1/2 ton SWB.
Thanks in advance!
Neil
Patsfan34 is offline   Reply With Quote
Old 03-24-2011, 10:22 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Suggestions on body mount/cab mount kit?
I'm in the same predicament. There's a lot of pros and cons on this subject. Some people like the new poly mounts because they're supposed to last longer. Others don't like them because they start to squeek sooner and are stiffer. Others say the old style rubber ones lasted for 20-30 years without problems so they're staying with OEM. I still undecided.
68gmsee is offline   Reply With Quote
Old 03-24-2011, 10:35 AM   #3
Patsfan34
Patsfan34's Avatar
If this was moved to the paint/body section or 4x4 section that makes no sense. Nobody goes to that forum. I'd appreciate it returned to where it was please!
Old 03-24-2011, 10:41 AM   #4
leddzepp
Moderator
leddzepp's Avatar
I would go with rubber for the cab mounts and poly for the suspension components for the reasons stated above by 68gmsee. Classicheartbeat is a board supporting vendor that carries the full kits.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-24-2011, 11:21 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
For the sake of comparison...Performance Suspension Technology. It's www.p-s-t.com
Member Nr. 2770
Old 03-24-2011, 11:44 AM   #6
cdowns
cdowns's Avatar
i tried poly mounts once and changed back to rubber in a few months and was much happier with over the road long distance driving// i do agree on poly for suspension pieces
Old 03-24-2011, 12:31 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
My feelings are no secret around here on this subject. Rubber mounts on body and urithane mounts for suspention. We have the complete 3/4 ton and 4x4 body mount kits in stock. (Including hardware) WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-24-2011, 12:39 PM   #8
stich626
ploy in suspention binds..
why no love for cab mounts, these trucks are not caddy's
stich626 is offline   Reply With Quote
Old 03-24-2011, 12:58 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Poly mounts for the cab are like riding on bricks. There is no movement in them at all. The whole idea of cab mount bushings is to absorb vibration and allow movement, to ease stress on welds, panel components, and glass. The rubber bushings allow the cab to move as a unit instead of twisting, like it would if it was bolted solid. When you use Poly cab mount bushings you are basically bolting it solid...
Just my 2¢ worth on the subject.
LockDoc
Leon
Old 03-24-2011, 01:03 PM   #10
Classic Heartbeat
Because these trucks have "C" channel frames, not boxed or tube. These frames are very flexible and rubber allows for frame movement. Urithane does not. I have had customers come in here where the body mount hardware has pulled thru the floor with urithane mounts, because of the movement of the frame. The bodies of these trucks are spot welded together and are not meant to be flexed and pulled around, so dammage happens when they do. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 03-24-2011, 01:07 PM   #11
cdowns
cdowns's Avatar
might not b a big diff for trailer queen or mall crawler but try a 600mile nonstop ride and the diff is very readily apparent
never had any binding in my suspension but always lubricated on a regular basis as part of normal maintenance
Old 03-24-2011, 01:19 PM   #12
stich626
thanks guess I'll send the poly's back..
Old 03-24-2011, 01:55 PM   #13
crazy longhorn
Fabricate till you "puke"
I have poly under my longhorn, & will say its a stiffer ride, but they were much needed,as the truck has a tilt front clip. The poly mounts ensure that the clutch engages @ the same spot every time For any off road, or hauler truck that will get flexed, rubber is for sure the way to go. In my case, the old truck is a cruiser, that I want to go straight when I drop the hammer(poly mounts & a stiff steel bed floor help with that). The poly engine mounts are a tad harsh tho....a lot more vibration is noticed. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-24-2011, 02:03 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I swapped the OEM mounts in a 71 K5 Blazer for poly mounts and regretted it. The ride was too rough for me and the mounts translated a lot of vibration into the cab. I switched back to a rubber set weeks later but kept the poly suspension mounts. I plan to use rubber cab mounts on both my 72 K10 and K20.
