Old 05-25-2011, 11:41 PM   #1
HSkinner
What shocks for a bagged front end?
I know this should probably go in the suspension section but I wanted to know what others have done with the 60-66 front end. Mines a 73-87 xmember that I put bags in. I didn't really modify anything other than remove the bump stops. When its aired out there is 8"s from the upper shock mount to the lower. Has anybody else found anything that lets the truck go all the way down and then back up without topping out the shock? Thanks, Heath
HSkinner is offline   Reply With Quote
Old 05-26-2011, 12:25 AM   #2
GGinferno
DiablosWeldingFabrication
GGinferno's Avatar
Re: What shocks for a bagged front end?
Shocks!?! what's that?! Hahaha! I run with out them and I ride like a Cadillac
GGinferno is offline   Reply With Quote
Old 05-26-2011, 12:36 AM   #3
HSkinner
tried that, I'd like to get it over 35 safely at some point...
Old 05-26-2011, 01:22 PM   #4
creep
Registered Loser
creep's Avatar
There are some aftermarket upper shock mounts that allow you to run longer shocks. I believe Portebuilt and Quality Air Ride both make them. May have to trim/modify the inner fenders though.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-01-2011, 04:28 PM   #5
chillware
CPP has the shock relocation kits, they around $35 last time i checked them on ebay.. Then you can use belltech nitro drop shocks..
My build thread: '66 Chevy
chillware is offline   Reply With Quote
Old 06-01-2011, 04:38 PM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
If you wanna do it on the cheap, I have 1949-50 Chysler Ney Yorker shocks on the front of my truck. They are one of the shortest out there and the price was less than 25 each. I dont remember the brand, but I think it was from Napa.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
