1 Wrench / 10 Knuckles
Has anyone made a pass with a bone stock 350 longbed with 307 gears? I've seen some posts here with impressive times for tricked 350's and was wondering what they turned before the mods.
1970 GMC Custom Vortec Heads, Edelbrock Performer Intake, Crane 272 Energizer, Hedman Full Length HTC Headers 2006 Dodge Charger SRT8. 1/4 mile 13.3 1973 Z1 900 Kawasaki ( all original) |
14.1 @ 96MPH
For a stocker, you'll be looking at anywhere from very high 16's to 18's...and I've seen a 4x4 put up even slower numbers, with the extra weight...
Project1970 - LS1 Swap Complete! ![]() |
Project 70
Your certainly not going to miss the race if you blink with those times!! Thats about what I expected. When I refered to " some impressive times " in my post it was you I was referring too. Are you planning any more mods this year? ![]()
geez..I thought maybe you were talking about mine..
"shake down time this year..13.40 at 102.7...woohoo..12.774 at 106.38 with a 75hp shot"
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Theres no question BIGJIMZ that yours smokes!!! It's just that Project 70 has done to his ...what I intend to do with mine.
Plus... I am a little bias with 70 GMC's ![]()
14.1 @ 96MPH
I'm flattered.
![]() Hopefully, this summer, if money allows, I'll be pushing quite a bit more horsepower...as it is, I've got "just" 230 to the wheels, tops. At the least, I want to put in a bigger cam (I have a 260H, want to go to an XE262H) and a set of headers along with a new exhaust all the way back, and add an H-pipe in. I'd like to at least rebuild the bottom end of the engine as well, and use that as an excuse to make it a 383...either that, or swap blocks and go for a 406! Regardless of how I do it, my horsepower target is at least 350...which shouldn't be too hard to hit, especially if I add the big cubes. It's all dependent on funds... That, and I also need to figure out why my 700R4 won't stay in first gear when it should be. Either that, or I need to adjust the governor so that WOT shifts happen on their own at 5500RPM instead of 4100RPM...
0 - 60
in 60 min ![]() |
If I remember correctly. My burb with a stock 350 and 3.07 did a 17.8?
Just sitting here contemplating contemplation. |
Location: Bondurant, IA but in Worcester, MA for school
My 70 C20 Chevy did 10.79 @ 62.96 MPH in the 1/8 mile last weekend at the track. Im pritty stock except for headers, HEI, and edelbrock carb. I also got 4.10s with helps a lot i think.
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
my truck went a 16.48 when it was stock
Justin weight 3480 with driver 1.35 60ft 6.13@111mph 1/8 mile 9.80@131mph 1/4 mile 434 small block all motor |
14.1 @ 96MPH
HotRod929: You'd probably cut a low-to-mid16 quarter...on those 15.7/86mph runs, I was running low 10's at 70mph.
