Somebody tell me what this is please, other then a black box
Whats this for? Is it the same for big block and small block? It was under the dash of both an '86 and '88 suburban I parted.
Thanks in advance |
It followed me home?
Re: Somebody tell me what this is please, other then a black box
Is that the power window module?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
I think it's the ...ECU? or whatever they called it for the electronically-controlled Quadrajets they had in 1985 and '86. My '86 C-10 had one that looked damn similar, but it was in yellow plastic rather than white and not on a big bracket like that. It was mounted on the passenger side where GM later mounted the TBI ECU's.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
#4 | |
#5 | |
Could it be for trailer brakes? I know a lot of Suburbans had tow packages. I have parted out a number of pickups and I never remember seeing one of those.
My other guess would be something to do with the factory radio. |
![]() Join Date: Dec 2010
I believe that is the knock retard ECU for the distributor - should have a knock sensor in the block that runs to it. They used this to retard the timing automatically when it sensed any engine knock.
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
Resident of Here
I think it's a trailer brake controller, a very basic one.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#10 | |
Conversion Truck Addicted
thats the computer for the cruise control
Thomas Quote:
The knock retard ECU for 85-86 CCC systems is mounted in the same location as the F/I ECU for 88-91 trucks, behind the glove box in a white tray. So thats not it.
In the Forgotten far North.
![]() Join Date: Jul 2007
That's exactly what that is. it mounts to the right of the steering column support just above the brake pedal. Item # 11 & 12 in the diagram
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Awsome Thank you guys!!
