Old 08-07-2011, 10:08 PM   #1
chevybuldr
chevybuldr's Avatar
Somebody tell me what this is please, other then a black box
Whats this for? Is it the same for big block and small block? It was under the dash of both an '86 and '88 suburban I parted.
Thanks in advance
chevybuldr is offline   Reply With Quote
Old 08-07-2011, 10:14 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Somebody tell me what this is please, other then a black box
Is that the power window module?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-07-2011, 10:17 PM   #3
Rogue_Alphonse
Rogue_Alphonse's Avatar
Thanks in advance
I think it's the ...ECU? or whatever they called it for the electronically-controlled Quadrajets they had in 1985 and '86. My '86 C-10 had one that looked damn similar, but it was in yellow plastic rather than white and not on a big bracket like that. It was mounted on the passenger side where GM later mounted the TBI ECU's.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 08-07-2011, 10:22 PM   #4
chevybuldr
chevybuldr's Avatar
No this is up near the ash tray area I think it was or the break pedel. The ECU is still in the '88 for the TBI.
Old 08-07-2011, 10:24 PM   #5
Rogue_Alphonse
I never really dug into that part of the dash enough to find anything like that... got me stumped!
Old 08-07-2011, 10:44 PM   #6
rwhit57
rwhit57's Avatar
Could it be for trailer brakes? I know a lot of Suburbans had tow packages. I have parted out a number of pickups and I never remember seeing one of those.
My other guess would be something to do with the factory radio.
rwhit57 is offline   Reply With Quote
Old 08-07-2011, 11:47 PM   #7
my4by2
my4by2's Avatar
I believe that is the knock retard ECU for the distributor - should have a knock sensor in the block that runs to it. They used this to retard the timing automatically when it sensed any engine knock.
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 08-07-2011, 11:50 PM   #8
chevybuldr
chevybuldr's Avatar
But on an '88 with TBI wouldnt that be in the ECU?
Old 08-07-2011, 11:58 PM   #9
thirdstreettito
Resident of Here
thirdstreettito's Avatar
I think it's a trailer brake controller, a very basic one.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-08-2011, 12:32 AM   #10
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
thats the computer for the cruise control
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 08-08-2011, 12:34 AM   #11
chevybuldr
chevybuldr's Avatar
Now that sounds like it might be.
Old 08-08-2011, 12:56 AM   #12
MalibuSSwagon
The knock retard ECU for 85-86 CCC systems is mounted in the same location as the F/I ECU for 88-91 trucks, behind the glove box in a white tray. So thats not it.
MalibuSSwagon is offline   Reply With Quote
Old 08-08-2011, 01:31 AM   #13
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
That's exactly what that is. it mounts to the right of the steering column support just above the brake pedal. Item # 11 & 12 in the diagram
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 08-08-2011, 01:42 AM   #14
chevybuldr
chevybuldr's Avatar
Awsome Thank you guys!!
