Old 08-14-2011, 11:57 PM   #1
bradford
Oil Pressure switch on TBI Engine
I got a TBI crate motor that Im about to slap in my truck next weekend.
I noticed it had what seemed to be two oil pressure sending units. One on top and one by the oil filter.
I assume it is for the TBI computer.
This motor has the mechanical fuel pump provision on it. I guess because its a crate/replacement engine?
I am putting an Edelbrock manifold and carb on it.
What do I need to do to utilize one of these oil pressure units?
Do I plug one of them? I guess I could use the unit off my current motor?
bradford is offline   Reply With Quote
Old 08-15-2011, 12:11 AM   #2
J Knight
J Knight's Avatar
Re: Oil Pressure switch on TBI Engine
I wouldnt use either one of them. put the sending unit off of your old motor in the same location as your old motor and plug the other hole.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 08-15-2011, 12:12 AM   #3
Zane M
The one by the filter is for the oil pressure gauge. The top unit is for the computer sending unit.
Zane M is offline   Reply With Quote
Old 08-15-2011, 12:13 AM   #4
Rogue_Alphonse
Rogue_Alphonse's Avatar
Originally Posted by J Knight View Post
I wouldnt use either one of them. put the sending unit off of your old motor in the same location and plug the other hole.
This.
when I took the TBI out of my C-10 [converted] and dropped it in my 1988 K5, I had to relocate the oil pressure sending units. The old 1988 engine had a blockoff cap for the other spot, which I used on the "new" engine.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 08-15-2011, 12:17 AM   #5
bradford
Originally Posted by Rogue_Alphonse View Post
This.
OK so the one on the side is where I need to put my old one on?
Old 08-15-2011, 12:24 AM   #6
Rogue_Alphonse
Where ever your old engine had its oil pressure pickup, use that.In fact, if it worked, use the one from your old engine. Figure out a way to cap off the other one. That's what I did.
Old 08-15-2011, 12:26 AM   #7
bradford
OK. Thats what I figured.
Thanks alot guys.
I cant wait til next weekend. I hope all my parts make it here before then.
