Old 02-01-2015, 09:17 PM   #1
2manyprojects
2manyprojects's Avatar
Junkpile Jimmy
I have a 50 GMC 1/2 ton short bed that I bought for a parts truck back in 08. I ended up selling the 49 Chevy and had this one sold a few times but no one ever showed with the money. Fast forward a few years, I needed a truck so I was going to throw some parts I had laying around at this one and have a beater. Well that idea got a case of the might as wells and I started buying parts as I ran across them. I'm finally making progress and buying new parts.
This is where I found it.
2manyprojects is offline   Reply With Quote
Old 02-01-2015, 09:22 PM   #2
2manyprojects
Re: Junkpile Jimmy
I borrowed a rollback picked it up and pulled the mangled fender off . It then sat until last summer.
Old 02-01-2015, 09:30 PM   #3
68shortwide
68shortwide's Avatar
Re: Junkpile Jimmy
I like it.
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 02-01-2015, 11:41 PM   #4
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Junkpile Jimmy
Heres a little motivation for you, Jimmy!
It's not mine but I LOVE this truck and especially the color
What is the plan for yours?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 02-02-2015, 12:15 AM   #5
2manyprojects
Re: Junkpile Jimmy
Originally Posted by 68shortwide View Post
I like it.
That truck is sweet and is kind of what I was going to do originally. The plan has changed a few times. As you will see when I post more to get caught up to where I am now.
I am going for a reliable daily driver with a clean lowered original look. the Motorvation will be a 270 GMC 6 with a T5. It will have a few updates like the trans but for the most part the newest thing on it will be 1957 I have spent enough money now that the plan probably wont change much going forward.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
Old 02-02-2015, 01:51 AM   #6
iowaboynca
iowaboynca's Avatar
Re: Junkpile Jimmy
thanks for saving another GMC
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 02-02-2015, 11:35 PM   #7
2manyprojects
Re: Junkpile Jimmy
Originally I had planned to do a S10 frame. I picked up another 50 GMC with a S10 frame . I ended up letting most of this stuff go when I sold the 49. The GMC did have a nice set of doors that I will be using along with some other misc things. The original frame had some bad rust or I wouldn't have cut it apart. The Chevy is the 49 that started it all.
Old 02-03-2015, 09:29 PM   #8
2manyprojects
Re: Junkpile Jimmy
After I decided to keep it and use the original frame ,I started buying parts when I ran across them. I picked up a rust free front clip , seat, and a 54 trans crossmember. At the time I planned to use a 292, sm420 4spd, and a 67 rear from my parts stash.
Old 04-11-2015, 06:51 PM   #9
2manyprojects
Re: Junkpile Jimmy
Sorry for the delay I did a YouTube worthy fall on the ice and haven't been doing much lately.
Around this time was when it started getting away from being a beater. Overdrive would be much nicer than a SM420 4spd .I picked up a T5 from a wrecked 85 Trans am with 40,000 miles . A week later while killing time at the local pick and pull I found a 88 S10 T5 sitting on the ground just picked it up and walked away without getting dirty. I also got a set of 51 front backing plates to get away from Huck brakes. I then ran across a 52 rear with 57 3.90 center section, new brakes and mounts already welded on.
Old 04-11-2015, 07:01 PM   #10
2manyprojects
Re: Junkpile Jimmy
My original cab is pretty rough so I have been on the look out . This one is much nicer and came with most of the patch panels I need to repair it. I plan to put all of the factory vents, crotch cooler, and gas filler hole back in it.
Old 04-11-2015, 07:18 PM   #11
2manyprojects
Re: Junkpile Jimmy
A few years ago my radiator was stolen by scrapers. I saw a ad on Craigslist for 49 Chevy parts. I went to take a look they had 2 GMC radiators. It was a kid his Dad and brother working on a 49 for his first ride. They needed a bed I was planning on getting a Mar -k so I said I would sell mine cheap. Late one Friday they called and wanted it the next day. That was my motivation to start the tear down. I put on a new set of shoes and pulled it out.
Old 04-13-2015, 12:30 PM   #12
2manyprojects
Re: Junkpile Jimmy
OK well my new computer died and Ive lost a bunch of tear down and part pics, but it was the usual take apart , bag , and tag deal.
Here's where am at now. I have to weld up a couple cut spots on the frame , remove the original bellhousing crossmember to install the 54, and its ready for blasting and paint.
Old 04-13-2015, 12:37 PM   #13
2manyprojects
Re: Junkpile Jimmy
I picked this up 2 weeks ago . 53 228 it runs great. I am supposed to go pick up the motor I plan to use next weekend. 57 270 . I might end up running the 228 temporarily depending on what the 270 needs.
Old 04-13-2015, 02:39 PM   #14
Advanced Design
Advanced Design's Avatar
Re: Junkpile Jimmy
Cool project! Nice shop set up too.
Advanced Design is offline   Reply With Quote
Old 04-13-2015, 03:36 PM   #15
2manyprojects
Re: Junkpile Jimmy
Thanks, the shop is nice it sure beats working in gravel . Luckily my Dad lets me keep all my junk there.
Old 04-20-2015, 07:46 PM   #16
2manyprojects
Re: Junkpile Jimmy
I went on a little road trip Sat to pick up my 270 it's out of a 57 350 2 ton . 15 hours , 600 miles round trip, one tank of fuel , a leaking AC compressor and sitting in DC traffic twice in one day is something I probably wont try again.
Old 05-05-2015, 08:21 PM   #17
2manyprojects
Re: Junkpile Jimmy
I'm on hold with this one for a few weeks. I am buying another truck . I will decide which one I want to keep once I get it home . I have also been organizing my mess and getting stuff together to get my panel going.
Old 05-07-2015, 08:17 AM   #18
68shortwide
Re: Junkpile Jimmy
Same, my trucks on hold too, i may or may not be finding a 69 Dart lol either that or a 95 Caprice 9C1/Impala SS. Good luck with the cleaning and organizing, its a pain!
Jack
1968 swb on air
Old 05-07-2015, 06:15 PM   #19
lower50's
lower50's's Avatar
Re: Junkpile Jimmy
Wow You come across a lot of nice parts. Watching this one.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-07-2015, 06:47 PM   #20
2manyprojects
Re: Junkpile Jimmy
I'm glad I'm not the only one that cant pass up buying cool stuff. The truck I'm getting is a 42 Chevy. If you end up with the caprice I have a 383 LT1 left over from one of my Trans Ams, that should really wake it up. I'm making progress on the organizing . Ive found stuff I didn't know I have.
Thanks , I just keep looking and buy when I find something for a decent price. It just takes patience which I normally don't have a lot of. I enjoy the search and the road trip to get it so that helps.
Old 05-09-2015, 04:18 PM   #21
2manyprojects
Re: Junkpile Jimmy
I spent all morning getting my Dads 55 Chevy running. I did manage to move some more junk around. Here are some more parts finds.
Old 05-24-2015, 04:48 PM   #22
2manyprojects
Re: Junkpile Jimmy
It was completely unplanned but it looks like this project is done. I picked up a 1942 Chevy 1/2 ton yesterday. It is a rough but complete original with very little rust through. The good thing is all of the mechanical stuff and drop axle I have for the 50 will work on this .
If anyone is interested in the 50 frame and body send me a PM.
Old 05-25-2015, 10:16 PM   #23
lower50's
lower50's's Avatar
Re: Junkpile Jimmy
Sweet looking 42'
1951 MG TD
Old 05-26-2015, 06:06 PM   #24
solidaxel
solidaxel's Avatar
Re: Junkpile Jimmy
I am in need of a grill piece from a 41 to 46 !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-26-2015, 09:32 PM   #25
2manyprojects
Re: Junkpile Jimmy
Sweet looking 42'
My grill is trashed. I will keep an eye for extra grills when hunting parts.
