Old 09-13-2011, 10:42 PM   #1
jojoman
gas smell in oil
i was just wondering if is bad to have gas smell in my oil i dont know if is really bad or just need a oil change i havent changed the oil since i got the truck since i dont drive it so any info thanks
jojoman is offline   Reply With Quote
Old 09-13-2011, 10:51 PM   #2
BMERDOC
BMERDOC's Avatar
Re: gas smell in oil
Not sure of your motor but your fuel pump diaphram could be leaking or your carb could be leaking. Oil shouldn't smell like gas, you have real problem. I heard about a electric fuel pump that stayed on and hydrolocked a motor on a very expensive show car. Not trying to scare you but...
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-13-2011, 11:30 PM   #3
Hevy
Hevy's Avatar
Probably blow-by from worn out piston rings.
Hevy is offline   Reply With Quote
Old 09-14-2011, 12:15 AM   #4
Eyegore
What Hump?
Eyegore's Avatar
Ditto, had the same thing happen in my blazer some 25 years ago.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 09-14-2011, 12:17 AM   #5
burb1085
burb1085's Avatar
I got the same problem in my T.B. injected 454. Plus I burn about a quart every 2-3 weeks.I cant think of any thing else but worn rings either. Thats about the only way the gas could get in the crank case is past the rings.
burb1085 is offline   Reply With Quote
Old 09-14-2011, 10:43 PM   #6
jojoman
well as far as i know motor was never really beat up on is a 383 it was getting flooded at first fix that now the timing is off could that have something to with it oh and also if i may add i have not done a tune up on it so if that explains anything
Old 09-14-2011, 11:34 PM   #7
SCOTI
SCOTI's Avatar
If it was flooding @ some point, gas more than likely has gotten in to the crankcase. It's not the end of the world but it's not a good situation either. An oil change ASAP is in order. It's not good practice to continue operation of the engines internals w/diluted lubrication abilities.
If the situation returns, then I would start digging to the motors condition further (blow by/poor ring seal, carb leaks, fuel pump, etc....).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-15-2011, 08:36 AM   #8
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
ive had this happen to me a few times and its always been a bad fuel pump.. change it and do a oil and filter and it should go away. This has always been on a carbueratored motor
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
