Old 11-22-2012, 04:23 PM   #1
John H.
John H.'s Avatar
1972 402 Napa engine rebuild kit
I have what looks like a complete rebuild kit I received with a truck I purchased.
The pistons are .30 over and comes with the following:
Aluminum pistons
Cam/lifters/bearings
perfect circle rings
Dana rockers and pushrods
Federal Mogul Made in USA rod and main bearings
timing chain and sprockets
freeze plugs
all gaskets unopened
oil pump
If you are looking for a factory stock 402 rebuild kit, this is an inexpensive way to start. Not sure of the age, but most components look like they are made in the good ole USA and are not discolored, surface rusted etc! Even if you are cleaning up or freshening up a 402, the price of gaskets and an oil pump begin to add up.
This box is very heavy.
$300 shipped to conus.
I can provide pictures if there is interest.
Trades?
John H. is offline   Reply With Quote
Old 11-22-2012, 04:39 PM   #2
t korinek
Truckin' Krazy
t korinek's Avatar
Re: 1972 402 Napa engine rebuild kit
Hi John, what are the specs on the bearings std or ? & how about a cam # or specs.
What parts are you looking for?
Thanks,
Tom
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
Old 11-22-2012, 05:55 PM   #3
John H.
John H.'s Avatar
Tom,
I need to get the specs from Napa. I am sure I will need to get them the part numbers and have them cross reference. The number on the kit box is 284-1249.
I could use a tach dash, rear fleetside sport bumper brackets,tilt, Parchment door panels with our without scroll as they will be covered, SB AC brackets with bolts, 4x4 exhaust manifolds.
Old 11-23-2012, 04:50 PM   #4
John H.
John H.'s Avatar
Rod and main bearings are standard size.
Cam:
Intake/Exhaust Cam lift .234
Intake valve lift .398
Exhaust valve lift .398
Overlap 57
Intake Duration 286
Exh duration 286
SAE int duration 270
ext duration 270
The spec sheet is attached, but you may need to download.
Name:  cam specs.png
Old 11-23-2012, 04:56 PM   #5
John H.
John H.'s Avatar
Name:  Cam specs.jpg
Old 11-25-2012, 11:12 PM   #6
t korinek
Truckin' Krazy
t korinek's Avatar
John, don't want to hold up your sale, I have 2 crankshafts already ground at 30/30, looking for something to go with that.
Heck of a price for someone though.
If you didn't find some one to buy outright, I would trade an RV tilt in great shape & a set of rear 4x4 sport bumper brackets aftermarket new.
Thanks,
Tom
Dealer for:
American Auto Wire
Dakota Digital
Trim parts Carpets
& Many others
