Old 01-28-2012, 02:04 PM   #1
72gmcshorty
72gmcshorty's Avatar
Carb and stock wire harness...
If i decide to go with a carb, how much of the original wiring harness is required. Being that my motor is 2006 and uses the pedal and tac, how does that work with the carb?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 01-28-2012, 05:57 PM   #2
6.0 1955
Re: Carb and stock wire harness...
You need crank sensor, cam sensor, coils, ground, computer hot wire, diagnostic wire and water temp sensor. That's all that's left on mine after a buddy fixed the harness. I questioned the temp sensor and he stated that the computer acts funny without the temp sensor reading. He's done swaps on many cars and tune's ls based cars for a living. It works good.
6.0 1955 is offline   Reply With Quote
Old 01-28-2012, 05:59 PM   #3
6.0 1955
Sorry I forgot to answer your other question. The tac module is for throttle control and DBW pedal. So in a carb setup they are not used.
Old 01-28-2012, 07:17 PM   #4
72gmcshorty
Anyone know what the cost of an aftermarket harness is for carb versus fi?
1992 Gmc 2wd
Old 01-29-2012, 04:58 PM   #5
mooseknuckles
mooseknuckles's Avatar
you don't need any of the original ls harness..just a MSD box to run the coils. you don't need the DBW pedal either....Edelbrock sells a intake and msd kit specifically for carb'd ls motors...
mooseknuckles is offline   Reply With Quote
Old 01-29-2012, 05:55 PM   #6
72gmcshorty
I know about this kit, i find it hard to believe i would need no harness to plug this into.....
1992 Gmc 2wd
Old 01-29-2012, 06:28 PM   #7
bo-w
its true , the carb takes care of fuel the box takes care of spark. what else do you need?
bo-w is offline   Reply With Quote
Old 01-29-2012, 10:52 PM   #8
mooseknuckles
just think, that intake and box, carb, and a eletric fuel pump and your ls motor is runnin.
Old 01-30-2012, 12:21 AM   #9
72gmcshorty
i have already bought a fuel injected gas tank, in tank fuel injected pump and sending unit and a corvette filter/regulator...now what...
1992 Gmc 2wd
Old 01-30-2012, 12:30 AM   #10
85burb
85burb's Avatar
Sell it all for a good low psi fuel pump. Or just sell the pump and run an intank low psi fuel pump. Buy msd 6010 if it is a 07 and older motor and a carb manifold and turn key.
p.s. The msd box comes with its own harnnes. None of the factory harness is needed. Except for the short harness that is on the coil brackets.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 01-30-2012, 11:31 AM   #11
6.0 1955
Guys I have both the MSD 6010 on the 1969 c10 and a carb setup ran by a factory computer and hacked harness on my 1955 chevy sedan. So you can pick up a used intake and use the factory harness, and have the fatory computer programmed. To me this was a cheaper alternative than the MSD box and is fully adjustable. The hacked harness has the same wires to hookup. Just my 2 cents
