high-Tech Red Neck
How about a 52 Chevy Dually 4x4 Welding rig?
I've been thinking about starting another project when I get up to Montana this summer.
I found this puppy for sale on craigslist. ![]() I have been looking around, finding lots of parts, been thinking about what I could put together with it. What I am envisioning is a fuel injected big block, NV4500 with a 205 or dana 300 and a Dana 44 and a Dana 60 up front and a P30 14 bolt out back. I was thinking some twinkie truck 19.5's and one of these puppies on the back on a custom made welding bed. ![]() ![]() I have several options I am considering, one is taking a 88-98 1 ton dually that already has the 5 speed and 454 then sectioning the cab from the 52 over the floor and firewall from the 88-98 Another is simply just moving everything over to the 52 and building new spring hangars and what not to make everything fit. I had also thought about seeing what it would take to make a 12 valve Cummins fit, These old trucks I know the hoods are fairly long, it might squeeze in. I don't know anyone who has done it so far. Right now this is all just food for thought, it would be a neat build if I built it. Thought you guys might get a kick out of looking at it.
"He used to be a pretty nice feller, now he's a welder!" |
Re: How about a 52 Chevy Dually 4x4 Welding rig?
MrBeast, I think that would be a great build. Hate to see your daully cut up though. I wish mine was a 2wd 4 door.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
high-Tech Red Neck
I won't be tearing one of mine down to build this if I do I will be buying a parts truck, I found an 86 4x4 that has a utility bed on it. The truck is pretty rough so it is ripe for parts.
That is kinda what I would like to do with this truck that I just drug home. I now need to find a 1 ton 4x4 dually donor truck.
Great idea! Have a look at these.The 48 looks in decent condition. A COE would be cool with a Cummins if you could find one at a reasonable price.
http://cgi.ebay.com/ebaymotors/1948-...item27d13eb023 http://cgi.ebay.com/ebaymotors/1948-...item1e78c19d30
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
#6 | |
high-Tech Red Neck
The 2nd one is cool but needs a lot of finishing. I am not very hot on how they did the floor boards. It would have been much more advantageous to build a new plenum with a front intake to keep the floor board wider. I am 6'1" 300 lbs, sitting with my right leg tucked up against the steering column doesn't sound very comfy.
high-Tech Red Neck
Cool! we need to see a build!
I saw this on welding web. I'm 1955_Chevy_6400 on there. Let us know how it goes!
Posted via Mobile Device |
I started building a service truck for the shop, but my son decided he needed it so now we're building this for my son as his welding truck....'54 6600 on a '92 3/4 ton dodge chassis with 5.9 auto, 2 wh. dr.... Soon to be 4 wh. dr. Took off the utility bed and we are putting a welding bed with a dual wheel one ton cab and chassis rearend and front end.
Cummins fits. Actually had to move the stock motor mounts back about 4 inches as I had too much space between the back of the engine and firewall. This gives me enough room for the radiator and inter cooler....Joe. ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
high-Tech Red Neck
Right now I am not going to pursue this project, I was thinking about it but I really need to get my 72 finished first. Been updating it pretty heavy if you guys are interested: http://67-72chevytrucks.com/vboard/s...d.php?t=278230
Any new updates? This is a cool build!!
My names Tye. No Chevy right now ![]() |
