1964 El Camino
G'day,
I own a 1967 GMC pickup and a friend has just bought a 1964 El Camino and needs some parts for it. If this is not the right place, can anyone tell me what is the best Forum for Elkys please? He has been to a few supposed El Camino sites, but they mostly seem to cater for the Chevelle coupe, rather than the "pickup". He needs a wiper motor mainly, are these interchangeable with any of our trucks? We're in Melbourne Australia, so that makes everything just a little bit harder when you need parts or information. TIA. Regards from Down Under. ![]() aussiejohn. Last edited by aussiejohn; 07-06-2012 at 04:08 AM. Reason: spelling mistake |
![]() Join Date: Sep 2011
Re: 1964 El Camino
Aussiejohn, Welcome to the board. I can't help with your question but I can say G'day mate! I won't put any shrimp on the barbie but I'd throw on a prawn or 2 for ya. Holler over to my mate Tony over Perth way would ya?
Someone knowlegable will be alonng soon, it's 4am here on the East cast, most of the yanks are sleeping.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Re: 1964 El Camino
heres some I found some they have different number of speeds and pictures then others so you should double check which one you need :
autozone has 1 speed and 2 speed motors: http://www.autozone.com/autozone/par...mString=search $68 1 speed motor/no washer pump: http://www.partsgeek.com/catalog/196...per_motor.html $99 1 speed: http://www.autopartswarehouse.com/de...QQA140119.html 1 speed motor: http://www.opgi.com/p/car-care/10910/7/CH28544.html 2 speed motor: http://www.opgi.com/p/car-care/10910/7/CH20280.html 2 speed motor: http://www.elcaminostore.com/el-cami...pump-1964.html 2 speed motor: http://www.ss396.com/mm5/merchant.mv...de=WIPERSYSTEM hope this helps
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
Collector of Projects
Re: 1964 El Camino
The EL Camino is acutally on the General Motors A-body platform. 1964-1967 then 1968-1972 are the two major age groups. They share parts with Chevrolet Chevelle / Malibu. Pontiac GTO / Le Mans. Also Buick, but I can't remember the models...
http://www.chevelles.com/ is a great resource and there are some Aussi folks on the forums too... |
1961 crewcab
Re: 1964 El Camino
yep, elcamino is chevelle , so almost anything you need for a 64 elcamino will interchange with a 64 chevelle, the 64 elcamino is basically a 64 chevelle wagon with no roof!
![]() obviously there are some elcamino specific parts: bed / door tops/roof, but you will be suprised what is available for these in the aftermarket. order up some chevelle/elcamino catalogs from year one, and original parts group. btw, to clarify; this is a pic of a 64 elcamino, is this what your friends car looks like?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Re: 1964 El Camino
Thanks a lot guys, I'm sure that we're headed in the right direction now.
jonz, that's exactly what it looks like, only metallic green. It has a worked 350 with twin four barrels on an Offenhauser manifold with progressive linkage. losthope, thanks for the great leads. We'll follow that up ASAP. Regards from Down Under. ![]() aussiejohn |
Re: 1964 El Camino
Oooh, I love me some early El's. Yes, Chevelle/Malibu they are, only slightly more useful thanks to the bed.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
