Old 11-30-2012, 12:31 PM   #1
raull
raull's Avatar
ls motor conversion brackets
up for sale i have these new brackets and mounts conversion kit from cpp for 1967 to 1972 c/10 trucks to fit the gm ls family engines , $150.00 shipped
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 11-30-2012, 12:39 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: ls motor conversion brackets
Raul's- do you have pictures of them installed? I'm trying to figure out what setup to do in my 68 when I upgrade to a 6.0. Also, I would appreciate your comments in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=551464
Thanks,
Rob
Hart_Rod is offline   Reply With Quote
Old 11-30-2012, 01:31 PM   #3
raull
raull's Avatar
here you go rob !!! in these pix its just the brackets moked on without mounts and the plates that bolt onto engine
raul
Old 12-03-2012, 08:59 PM   #4
Hart_Rod
Hart_Rod's Avatar
Raul - do you have the plates that bolt to the motor also?
Old 12-03-2012, 11:30 PM   #5
raull
raull's Avatar
sorry i guess i should've post this also , yes i do and all hardware in its original package !!!!!!!
raul
Old 12-04-2012, 10:11 AM   #6
Hart_Rod
Hart_Rod's Avatar
Do you have a part number for the LS plates that bolt on to the motor? Apparently there are 3 different versions which place the engine in different positions.
Old 12-04-2012, 10:26 AM   #7
raull
raull's Avatar
there are no numbers on the plates , this is the kit from cpp ,i guess ill call them later to ask
raul
Old 12-04-2012, 01:02 PM   #8
raull
raull's Avatar
mine are the ls1k3 which moves the engine 3 inches foward , here is the link that shows illustrations on all brackets ,
http://www.classicperform.com/Instru...PDF/LS1-K3.pdf
raul
Old 12-04-2012, 06:16 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
So what oilpan does this work with?
John
1999 Toyota Tacoma 4x4
Old 12-04-2012, 06:17 PM   #10
oldblue1968chevy
So these are only for LS1 engines?..
John
Old 12-05-2012, 01:56 PM   #11
raull
raull's Avatar
hope this helps , this set up is for ls1 oilpan on pix no# 1 , i was going to use a truck ls motor pix #2 which has a pan that sits even further back with more crossmember clearance
raul
Old 12-05-2012, 02:06 PM   #12
Hart_Rod
Hart_Rod's Avatar
Thanks Raul. I think I need the plates that move the engine further back. I'll let you know when I figure it, hopefully you'll still have them....
Old 12-05-2012, 02:30 PM   #13
nlped
nlped's Avatar
Just to clarify...This included the mounts, tubular stands, ls1k3 plates, all the bolts & hardware + shipping, correct?
If so, I think I'll take 'em.
Thanks,
Ed
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-05-2012, 11:34 PM   #14
raull
raull's Avatar
Thanks,
Ed
that is correct !!!
raul
