What radiator have you used on your s10 AD truck projects.
What radiators have you guys used on your projects. I have built a s10 swap before and used a 67 mustang radiator I believe. But I had to have the lower snout cut and moved over to get clearance. Just curious if there is anything else out there. It would also be nice if there was a trans cooler built in as well. Any help is appreciated. Thanks
51 Chevy Truck S-10 Chassis Bagged http://67-72chevytrucks.com/vboard/s...d.php?t=545820 49 Burb with a 5.3 LS swap http://www.67-72chevytrucks.com/vboa...d.php?t=612572 Find us on Facebook https://www.facebook.com/pages/Smitt...s/252838673654 |
Re: What radiator have you used on your s10 AD truck projects.
I plan on using my stock radiator. Looks to be a 4 core. I am still in the construction/experimental stage. but will keep an eye on the gauges once I get it going under its own power.
and a few others
I'm using Speedway Motor's 19x22. Sorry no pics, I don't have it installed yet.
$115.99 No trans cooler though. I'm gonna use an external. Inlet/outlet set up for SBC. http://www.speedwaymotors.com/Speedw...tors,3557.html
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
![]() Join Date: Mar 2007
Since I am running an LT1 I needed the inlet and outlet reversed from the normal locations for a small block so this is what I used
Champion Cooling Product Code: CC180 70-80 Land Cruiser radiator. Core Dimensions: 17 1/8" high x 19 1/2" wide (3 row core) Overall Dimensions: 21 3/4" high x 22" wide Upper inlet: 1 1/2" located on drivers side. Lower outlet: 1 1/2" located on passengers side The nice thing is the bottom tank is shallower on the driver side allowing me to clear the steering box. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
I'm using a '64-66 Mustang 3 core V8 radiator and shroud. Fits great and keeps my 350 cool.
Ok thanks for the suggestions. Maybe I should have went into detail a little more. I am going to be running a LS series engine. I need both of my hoses on the same side. The passenger side of the truck. Does anyone have an LS in their truck and if so what radiator did you use. I found one through speedway I think I am gonna give a try. It has them both on the same side like I need just no trans cooler. I guess I can put an external cooler on. I found a couple of those I like as well.
I used a 19x22 in my last build on this truck, with a 4.3. I'm in the process of putting a 5.3 in it right now and also exploring radiator options. Have you done any mocking up yet? Are you planning on buying a new thermostat housing? Also you'll want to look for a radiator with the smaller, LS sized necks (1.5 "lower, 1.25" upper).
Here's a mock-up picture with my old 19x22: ![]() Here's how the original water neck orientation: ![]()
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 12-21-2012 at 04:35 PM. |
Haven't really done any mocking up yet. I have had the whole front end hung on the truck and fitted but I dont have any radiators to test with. Everything I have measured a 19x22 looks like my best option. Whats the deal about the thermostat housing. Are you talking about buying one that you can point in another direction or something?
Yes, I've been doing a little searching on that, straight out is an option. See the picture above.
There is a cheap one on eBay $30something that uses a SBC thermostat...but that doesn't work well with the LS waterpump and water will bypass the heater core. There is another I've found that uses the correct style thermostat, that's the one I'm looking at. http://www.ebay.com/itm/CBM-10613-GM...983173&vxp=mtr
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#10 | |
#11 | |
My motor is pretty low. I swapped to the H3 oil pan to buy some clearance, and it's within 1/2" of the crossmember on the passenger side. My build thread shows some good pics of how it lines up on the front of the frame. The passenger side fender brace is resting on one of the coil packs, but more will have to change to have the Sandin compressor over there so I'll address that later.
