Old 02-05-2013, 10:52 AM   #1
77ChevySharkBite
77ChevySharkBite's Avatar
700r4 and 4l60e
Hey everyone I have a question I'm in the process of looking to get me a new tranny for my truck that th350 ain't cutting it for me haha
I'm looking into getting a 700r4 or 4l60e, what mods would have to be done to get it to fit? If I'm not mistaken isn't the 700r4 just a bolt in if I'm wrong please do correct me, but I'm trying to find out some more info on them.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 02-05-2013, 11:22 AM   #2
rs72z
rs72z's Avatar
Re: 700r4 and 4l60e
The 700 is pretty much a bolt in. You have to slide the crossmember back, i set of holes should line up maybe both. drives shaft is the same. You will need to hook up the lockup and there is several ways of doing that.
The 4l60e is computer controlled.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 02-05-2013, 11:25 AM   #3
77ChevySharkBite
Re: 700r4 and 4l60e
Alright, awesome!!! I found one for about $200 here in Houston, so i was going to try and pick it up, because I want to put a 4 speed in the truck.
Korwin
Old 02-05-2013, 11:30 AM   #4
blazer2007
Re: 700r4 and 4l60e
driveshaft has to be shortened doesn,t it ?
blazer2007 is offline   Reply With Quote
Old 02-05-2013, 12:27 PM   #5
rs72z
rs72z's Avatar
Re: 700r4 and 4l60e
If the truck has the correct long tail shaft 350 in it the driveshaft will work.
If it has the short shaft then it will need to be shortened.
___________________
78 ccsb dually
5.3
4l60e
Old 02-05-2013, 12:32 PM   #6
77ChevySharkBite
Re: 700r4 and 4l60e
well I just have a 305 but I know the 305/350 are hand in hand same motor just one is a 5.0 compared to the 5.7.
Korwin
Old 02-05-2013, 11:51 AM   #7
OC 72
OC 72's Avatar
Re: 700r4 and 4l60e
The 200R is about the same size as the 350...the 700R needs to have the driveshaft shortened.
OC 72 is offline   Reply With Quote
Old 02-05-2013, 11:57 AM   #8
77ChevySharkBite
Re: 700r4 and 4l60e
Okay, glad to know that I'm trying to see what I all need in advance that way I can prepare a little bit better for it.
Korwin
Old 02-05-2013, 12:42 PM   #9
77ChevySharkBite
Re: 700r4 and 4l60e
I know this might throw everyone for a twist but what all does it take to convert a th350 to a th400?
Please ignore this post.
Old 02-05-2013, 01:02 PM   #10
rs72z
rs72z's Avatar
Re: 700r4 and 4l60e
What i was referring to was the 350 trans being a long shaft.
___________________
78 ccsb dually
5.3
4l60e
Old 02-05-2013, 01:05 PM   #11
77ChevySharkBite
Re: 700r4 and 4l60e
Oh okay. Thanks for the help!
Korwin
Old 02-05-2013, 01:09 PM   #12
77ChevySharkBite
Re: 700r4 and 4l60e
rs72z, would it be possible to convert the 4l60e to run with a carb 305 or do you have any knowledge of it?
Korwin
Old 02-05-2013, 03:35 PM   #13
rs72z
rs72z's Avatar
Re: 700r4 and 4l60e
The 4l60e will require a computer to run. I think there is some stand alone units out there, at least there is for the 4l80e. It would be cheaper to just find a 700 vs the 4l60e.
___________________
78 ccsb dually
5.3
4l60e
Old 02-05-2013, 03:50 PM   #14
77ChevySharkBite
Re: 700r4 and 4l60e
Yeah, and I'm sure the hassle of all the work to be done just to get it to fit wouldn't be worth it either.
Korwin
Old 02-06-2013, 07:50 PM   #15
Duster
Duster's Avatar
Re: 700r4 and 4l60e
I don't know if you will like a 700r4 anymore than you will your th350 unless you do a bunch of highway driving. I have had both, and I like my th350 better than the 700. th350's tend to last longer than a 700 also. It just depends on what you are doing with it.
Duster is offline   Reply With Quote
