Old 02-09-2013, 10:26 PM   #1
MyDad'sTruck
Stock 68 1/2 ton 4x4 Needs Lift - Help.
If anyone can recommend manufacturers of a 3 or 4 inch lift and any other needed equipment, I would appreciate it. MN doesnt have a lot of vintage vehicles so its hard to find around here. THanks!
MyDad'sTruck is offline   Reply With Quote
Old 02-13-2013, 04:11 AM   #2
Chevymaniac
Re: Stock 68 1/2 ton 4x4 Needs Lift - Help.
No lift kits for your year of truck. Will have to piece together a lift kit. There is a thread on here done by Mr-Jack, which has a good write up on what he used to achieve his lift. Hope this helps you out.
Chevymaniac is offline   Reply With Quote
Old 02-13-2013, 12:25 PM   #3
vectorit
What?
vectorit's Avatar
Call Deaver Suspension.
They build new systems, and I have talked to them before about my '68 K20.
www.deaverspring.com
The deal with the 67-68 is that the OE springs are wider at the shackle than the 69-72 versions, so in order to use the 69-72 spring you will have to use a steal collared bushing and a spacer in each side to center them in the shackle.
I am shopping for new springs right now, but I am looking for 2" or 2.5" lift.
Deaver systems only offer 4" and up, so I am looking else where like Skyjacker at the moment.
Member "Mt Man Chad" did a little write up on using 69-72 springs on his burb.
http://67-72chevytrucks.com/vboard/s...=456901&page=4
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-13-2013, 12:29 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Here's a link to Mr-Jack's inquiry thread, which contains some info and links: http://67-72chevytrucks.com/vboard/s...d.php?t=391934
And here's his build thread (His truck is a '67 btw): http://67-72chevytrucks.com/vboard/s...d.php?t=478707
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-13-2013, 07:44 PM   #5
cmy_1972
Call Skyjacker in West Monroe, LA. I have a 69 4 X 4 and a 72 Jimmy and have Skyjacker 4" lifts on both. They are awesome and ride so good. http://skyjacker.com/
I got the kit with new front and rear springs, shackles, front and rear shocks, front steering stabilizer and everthing. Make sure you ask for the frame bushings that go in the frame on the rear mount of the front springs. They do not come in the kit and they are only $25 extra
cmy_1972 is offline   Reply With Quote
Old 04-06-2013, 08:56 PM   #6
MyDad'sTruck
This has been helpful, thanks guys!
Old 04-06-2013, 09:21 PM   #7
MyDad'sTruck
If you find the 2.5 inch lift, please post results and info. I think 4 is too high for me too. love the history of the truck, we bought ours brand new too.
