Old 04-29-2013, 01:48 PM   #1
simthizzle
What steering column will work in my 66?
I need a new column in the 66. What years will bolt in it? 70's 80's work?
simthizzle is offline   Reply With Quote
Old 04-29-2013, 01:51 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: What steering column will work in my 66?
`66 to `86 truck and or vans if you want keyless, the trucks will have key starting in `72, and some tilt.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-29-2013, 01:53 PM   #3
simthizzle
Cool. They all bolt in the same tho?
Old 04-29-2013, 02:02 PM   #4
Rich 5150 69
http://www.persh.org/pickup/steering.htm
go here...
Old 04-29-2013, 02:27 PM   #5
tincan1966
tincan1966's Avatar
None are a direct bolt in except for the '64-66 columns, or an aftermarket made specifically for them.
I have a 1994 Chevy Suburban column in my '65 C10 but the mounting brackets and column are both heavily modified.
tincan1966 is offline   Reply With Quote
Old 04-29-2013, 06:39 PM   #6
usnabill
usnabill's Avatar
I mounted a 63 in my 66 with no modifications. Before 63 I think they used a different bracket.
usnabill is offline   Reply With Quote
Old 04-29-2013, 08:47 PM   #7
tincan1966
tincan1966's Avatar
You are right- I forgot about the '63
Isn't the '63-66 all have the "modern style" turn signal switch and the 60-62 have the remote style mounted lower on the column?
Old 04-30-2013, 01:06 PM   #8
luvbowties
luvbowties's Avatar
Smile Re: What steering column will work in my 66?
Motor homes up into the early to mid 70's usually have a keyless column and many have tilt...got one from a 73? or 74? one-ton m-hm. & it worked beautifully in my '66; so did the p-steering pump, brackets, lines, and gear box. Yes, the 1/2 ton thru the 1-ton truck gear boxes are interchangeable during those years; they do not turn backwards like the G10-G20 vans! So, while plundering in the yards, do not overlook these options!
Sam
luvbowties is offline   Reply With Quote
