Old 12-27-2014, 07:49 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
removing gauge cluster
So I figured I would remove my gauge cluster to aid in removing the brake pedal assembly. I removed all the screws I think I need to but it won't budge. Also, how is the speedo connected to the gauge? I can get my hand somewhat back there but figure if I can get the gauges out a little I would be able to disconnect it? Thanks for any help. This is on my 86 K5.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-27-2014, 07:55 PM   #2
enaberif
Re: removing gauge cluster
Dash pads are a PAIN to remove sometimes. Once ALL of the screws are out including those along the lower part near the glove box (I think there is 2 or 3) then it just pulls out towards you.
enaberif is offline   Reply With Quote
Old 12-27-2014, 08:02 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The dash pad has to come out too?
Old 12-27-2014, 08:04 PM   #4
Just call me Sean
Just call me Sean's Avatar
He wants to remove the cluster, not the dash pad. The dash pad doesn't have to come out to remove the cluster, but it would make it slightly easier.
There's a clip you push to unhook the cable.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-27-2014, 08:06 PM   #5
enaberif
Doesn't have to but makes things so much eaiser.
Old 12-27-2014, 08:13 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks. Looks like I will have some fun tomorrow.
Old 12-27-2014, 08:23 PM   #7
jratz1966
jratz1966's Avatar
what I've did in the past is push the speedometer cable in from under the hood,this should allow you to pull the cluster out enough to make it easier to push the clip that hold the cable on.
jratz1966 is offline   Reply With Quote
Old 12-29-2014, 04:47 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks jratz. That is what I did. Made it real easy to remove.
