Old 06-02-2013, 11:11 AM   #1
rs74
rs74's Avatar
Did Chevy make a "Hi-Boy" version?
The guy I bought my K30 from said he had what he called an 83 Chevy Hi-Boy 4x4. I know the Hi-boy is a ford term but that is how he put it to me. He said from the factory it set up pretty high like it had a factory lift kit or something. I am thinking he said it was a 3/4 ton 4x4 chassis. just curious.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 06-02-2013, 11:22 AM   #2
factorystock
factorystock's Avatar
Re: Did Chevy make a "Hi-Boy" version?
Last year of Chevy building a 4X4 pickup that resembled a "Ford Hi-Boy" was 1966.
factorystock is offline   Reply With Quote
Old 06-02-2013, 11:41 AM   #3
rs74
rs74's Avatar
My thought was they didn't but I wasn't for sure.
Roy
1987 R10 shortie
Old 06-02-2013, 02:54 PM   #4
Zane M
If it was lifted from the "factory", it was actually most likely done by the dealer.
Zane M is offline   Reply With Quote
Old 06-02-2013, 09:37 PM   #5
b454rat
A true 1 ton will sit 2" higher than a 1/2 or 3/4 ton will. The frames are 2" taller....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 06-03-2013, 02:05 AM   #6
andrewmp6
High boy was a nickname for factory lift on a 70s ford truck ,As far as i know gm never done it but like said a 1ton will **** higher then the rest of the trucks.
Old 06-03-2013, 03:19 PM   #7
kevinr1970
I am under the impression that that difference is only from about the firewall back (give or take); the frame from the firewall forward is the same no matter what?
Originally Posted by andrewmp6 View Post
... 1ton will **** higher then the rest of the trucks.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 06-03-2013, 07:06 PM   #8
b454rat
yes you are correct...
Old 06-07-2013, 11:15 PM   #9
factorystock
Here are the facts guys :1966 was the last year of the "Hi boy" pickup (repeat of earlier post #2).
Old 06-08-2013, 09:51 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
He's right with that diagram.
The Ford Hi-Boy used a divorced transfer case.
Tx Firefighter is offline   Reply With Quote
Old 06-08-2013, 03:13 PM   #11
cory d
cory d's Avatar
its not. the rails above the cross member on my buddies half tone where highrer than the ones on his 1 ton
cory d is offline   Reply With Quote
