Coil Spring Plates
After cleaning up my frame I noticed right where the spring perch mounts to the plate on the frame, there is some rust accumulating.
Is it safe to remove the rivets and clean up and bolt back with some grade 8? Any particular bolt size that is good for stock rivets? I hear 10mm might work? Thanks |
Re: Coil Spring Plates
should be just fine with grade 8 bolts, from the pic tho looks like they are kinda sagging in the middle?
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
Yea that is rust in the middle that is making them sag.
I wanted to grind off the rivets, clean em up and bolt em back in. I hear 10mm or 7/16 will do the trick? Any ideas as to which will fit better? |
more than likley 7/16
I just went out and measured a rivet hole and it measures .41". I have been drilling them out to 7/16" and installing 7/16" (.4375") grade 8 bolts. A 10 mm bolt converts to .3937" so it may be decent in a .41" rivet hole but you don't want to have any slop in the hole because it will shear off easily on impact.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 07-12-2013 at 08:19 PM. Reason: add |
Lmc makes a complete kit to replace all rivets with grade 8.
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
you can get the rivits out and run a 7/16 tap through the holes without drilling them helps keep everything snug.
i will say the tap will not take a full bite into the hole but it will leave a good enough thread too be able too snug the metal together without useing a nut (just sayin)of course your gonna wanna put nuts on. you can attack the rivit with a combo of a cut off wheel/grinding disc,drill,or a cold chisel &bfh. what i found too work good was to cut a x into the head of the rivit and knock it off with the chisel.of course you could drill a hole an knock'em off also
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
