dead burb 1972 gmc
I have replaced the starter, the positive terminal, the key tumbler , the ignition bracket the tumbler goes into, it still has no result when i turn the key. any ideas?
![]() Join Date: Oct 2004
Re: dead burb 1972 gmc
Make sure your battery is good and you have a good ground.
battery is good and the connections are strong. and even hooking jumper cables up, still gets no result when i turn the key. the lights and stereo will come on, but no other sound from the key switch. just dead.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Is it an auto trans with nuetral safety switch? Need to get a test light and start tracing where you have power and where you don't.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
![]() Join Date: Apr 2005
+1
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
when i bought it and looked under the dash , it had one of those crazy damn security systems with wires going everywhere! it is all tapped into the back of the ignition and i am thinking that is where the problem is.
![]() Join Date: Jan 2003
Fusible link? Do you have the second power lead to the fuse box hooked up? It bolts to the inner fender on an isolator, which feeds the fuse block.
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
found the issue! when i replaced the starter and the positive battery terminal going to the starter, i only reattached the thin starter wire going back to the ignition. it had worn through in several spots. replaced that and voila, shes running again!
Congrats! Glad ya found it.
Glad you found what was the issue!!
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
