250 4 barrel linkage
I am just finishing up the T5 swap in my 66 c10 and want to move on to freshening up the engine. My plan is to reseal, paint and detail. But while I am in there I would like to do a few mods. I want to use split manifolds, an offy intake, carb upgrade, ignition, and possibly a mild cam. So my question is what carb is the easiest to make most of the stock throttle linkage work? I am thinking the holley 390 running parallel with the engine? I dont really want to start using aftermarket throttle cables etc if I do not have to. Any suggestions would be greatly appreciated, thanks.
Re: 250 4 barrel linkage
Any carb will work if you use a bell crank. Offy intakes mount the carb sideways. Clifford intakes mount them parralel.
I had an Offy with a holley 350 and used the stock rod linkage and a bellcrank. Here's a link for a bellcrank and a link to see some tricked out sixes to get ideas from. http://www.speedwaymotors.com/Mr-Gas...Kit,36221.html http://67-72chevytrucks.com/vboard/s...d.php?t=276823 |
Thank you, is there Any advantage with the Clifford intake instead of the offy?
Posted via Mobile Device |
Only other difference is in the ability to add heat to the intake. The Offy uses a bolt on plate and the Clifford has a heat chamber built in to it.
If you live in a cool climate that might be something to look at. |
#5 | |
![]() Join Date: Mar 2013
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Ok thanks I will probably use a Clifford intake and Langdon headers. So the stock linkage should be useable with Clifford intake and 390 holley? Thanks guys
The original linkage should have a rod that runs to the bell crank. If you extened the rod to the middle hole on the carb you should be able to hook it right up. Vernski( One of the member here) did this. You could have him send you pictures of what he did, and that would help you quite a bit. I went with a lokar pedal and cable setup and had it all installed in an hour.
I would look here for info http://67-72chevytrucks.com/vboard/s...d.php?t=276823
