66 250 engine paint
Where could someone find the correct blueish green paint?
Re: 66 250 engine paint
For my 1964, I've bought GMC Blue at OReilly's Auto Parts, and it is a perfect match.
I had this color matched from my '66 250, I think 230's were the same color. We used Mack truck paint code 14704, "jet turquoise". We left part of the white and black out when mixing the paint, then added them back in until we got it close. If I remember right, I think we ended up adding more black than the code called for. I may still tint it a little darker to match better, but that code will give you a good starting point. Different lighting conditions throw the color off between these two pics, and it has much more of a green tint in person.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
I just went out to the garage and looked at the can that I got at OReilly's. It is Dupli-Color Engine Enamel, 500 degree ceramic. The number says DE 1608 G.M. BLUE. To my eye, it is a perfect match to the blue on the 230 in my '64 C10. So far, I've painted the valve cover, new water pump and radiator hose spout and it looks like a perfect match against the original paint still on the block.
Moderator
![]() Join Date: Dec 2012
This is how Eastwood's Ceramic Engine Paint Chevy Blue turned out. I think it is very close to my original 1965 230ci color. This is my 1971-72 250ci.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
