Old 12-15-2013, 01:01 PM   #1
Metalaroundstone
Question about ignition timing on 327
Attachment 1187607I have a question about the proper timing spec for the 327 engine in my 1966 c10, which has a 4GC carburetor and no air injection reactor. Right now I have it at 8 degrees BTDC, with vacuum advance disconnected and port plugged. However, when I look at the specs in the service manual addendum for 1966, it says the timing should be set at 2 degrees BTDC. The 1963 service manual, on the other hand, says it should be 8* BTDC. My truck doesn't seem to like a 2* BTDC reading. I would appreciate any advice any body has on what the ignition timing ought to be and why these two spec sheets are so different for the same engine?
Metalaroundstone is offline   Reply With Quote
engine specs, ignition timing, specifications, tune up
