Question about ignition timing on 327
Attachment 1187607I have a question about the proper timing spec for the 327 engine in my 1966 c10, which has a 4GC carburetor and no air injection reactor. Right now I have it at 8 degrees BTDC, with vacuum advance disconnected and port plugged. However, when I look at the specs in the service manual addendum for 1966, it says the timing should be set at 2 degrees BTDC. The 1963 service manual, on the other hand, says it should be 8* BTDC. My truck doesn't seem to like a 2* BTDC reading. I would appreciate any advice any body has on what the ignition timing ought to be and why these two spec sheets are so different for the same engine?
Re: Question about ignition timing on 327
Is the engine original, has the heads been changed, camshaft, vaccum advance have the correct vaccum dashpot, distributor mechanical advance working correctly no broken springs, not sticking or worn advance stops, a lot of variables here.. give us some history...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
You need to go with what works good. Like Rich says, there are variations. I would try about 10-12 degrees. If it runs smooth & doesn't ping on hard acceleration, or try to kick back when starting , this will work good. If not move it back to 6-8 degrees.
#4 | |
#5 | |
NOMADSC.C.
I use a vacum guage to set timing
The more advance you put in it ( to a certain point ) the better it will perform and better gas mileage as well. I have a 283 with stock HEI and with the vacuum connected its at 52* at idle. But the vacuum cuts out and the mech side takes over as soon as I crack the throttle. The engine runs amazing now, its low compression so it doesn't ping. Adjust it to your engine, seat of the pants, if you do have a vacuum gauge and it starts bouncing at idle you've gone too far advance.. I know original dist with points is cool but it will run better with an HEI, keep the engine chambers cleaner, smell better, start easier, better mileage and probably more timing that will wake that small block up!
#8 | |
#9 | |
60-66 Nut
The initial timing isn't as important as the total timing. You want about 34-36 degrees at 3000 rpm with the vacuum advance disconnected. I would try connecting your vacuum advance to manifold vacuum and see how it likes that. There are quite a few threads about setting your timing, in the 'Engine and Drivetrain' section here on the forum.
#11 | |
| Bookmarks |
| Tags |
| engine specs, ignition timing, specifications, tune up |
