Old 02-13-2020, 10:13 PM   #1
Patrat
Junior Member
suggestions for converting to disc 87 4wd
87 Suburban 4wd wanting to convert to front discs.
Any advice? Suppliers? Do's & dont's?
Patrat is offline   Reply With Quote
Old 02-13-2020, 10:25 PM   #2
mongocanfly
mongocanfly's Avatar
Re: suggestions for converting to disc 87 4wd
87 without front discs?...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-13-2020, 10:29 PM   #3
Patrat
Junior Member
3/4 ton
Old 02-13-2020, 10:32 PM   #4
kipps
Better check again. A 3/4 ton '87 suburban should already have front discs.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 02-14-2020, 12:09 AM   #5
mongocanfly
Ditto...in about 71 or so front drums went away
Heres a older thread on it...http://67-72chevytrucks.com/vboard/s...d.php?t=200141
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-14-2020, 08:40 AM   #6
I would say if there are drums up front, the front axle got changed with a 1970 or older version axle. AS mentioned it would have had disk brakes from the factory
Old 02-14-2020, 11:56 AM   #7
Ziegelsteinfaust
Easiest way is to swap the axle.
Very few kits out there, and Suburban 10 bolts or Dana 44's are cheap enough.
Ziegelsteinfaust is offline   Reply With Quote
Old 02-14-2020, 09:47 PM   #8
Patrat
Junior Member
This is a case of the blind leading the naked, son-in-law was sure they were drums but after I told him the experts had weighed in and made him go check, turns out they a disc indeed.
Thanks everyone for the help, now I get to go find out why the truck does not stop like it should.
Old 02-14-2020, 10:38 PM   #9
mongocanfly
Ok that's settled...now what's the issue with the poor stopping..what exactly is it doing.. or not doing
Mongo...aka Greg
RIP Dad
RIP Jesse
