Old 03-23-2014, 03:46 PM   #1
lutronjim
Power Steering Hose
What power steering hose is available to connect new pump to old gear box? I know the threads are differ on each end.
lutronjim is offline   Reply With Quote
Old 03-23-2014, 04:40 PM   #2
truckdude239
truckdude239's Avatar
Re: Power Steering Hose
what year truck?
on my 71 c-10 i swaped the 1 inch fitting in the back of the new pump from a pump of the same year as the my truck and used the stock hose, the fitting cost my 72 cents at the local junk yard and since i can use the stock hose i can get one at any store if it ever goes out
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-24-2014, 12:52 AM   #3
First c10
First c10's Avatar
I had replaced my original pump with an Oreillys pump before the swap. The replacement pump had the correct fitting on the pump I just transferred the fitting and lines to the lsx pump. Fit like a glove. Maybe you can check to see if your pump had been replaced and has the fitting already. Keep us posted
Good luck.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-24-2014, 10:34 AM   #4
lutronjim
Thanks Never had a pump apart. Pushing 300k on a project engine I got from a buddy. Does the high pressure fitting unscrew to remove tank? If so I suppose I could just swap fittings from my pump to new one.
Going to swap in a Chevolet performance 'connect and cruise' package.
I an going to get the Vintage Air Gen IV system and their LS FrontRunner™ Drive System. This put compressor high and avoid frame mods.
Old 03-24-2014, 10:35 AM   #5
lutronjim
Forgot to answer. Its a 70 side side short bed.
Old 03-24-2014, 03:22 PM   #6
truckdude239
Yup the high pressure fittings will swap
David fuller
2000 Tahoe 5.3l 378
Old 03-24-2014, 04:06 PM   #7
Andy4639
Old member
Andy4639's Avatar
Cool Re: Power Steering Hose
The fitting on the backside of pump will unscrew and screw right back inside the new pump. At least thats how I and Hawks did it. It's spring loaded so be carefull when taking it a part. I thought I had lost part of it and looked all over the floor for parts. Finally realized it didn't.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-24-2014, 07:15 PM   #8
crazy longhorn
Fabricate till you "puke"
I run an 84 Burb box on my old ride (metric/o ring fittings)....the stock 2000 GMC hose fit the mess, on my old 69 with just a 'tweek" on the return line on the pump You really have to love some of the mix/match on parts over the yrs! Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-24-2014, 09:59 PM   #9
ls1nova71
ls1nova71's Avatar
You'll need to do some research, but I don't think the VA frontrunner system comes with a truck style power steering pump, I believe they use an F body type pump, in which case you can't swap out that fitting.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
