Old 03-24-2014, 01:06 AM   #1
blazercrazy70
blazercrazy70's Avatar
tire height
getting ready to order tires for my showwheels they are 20x10 in the rear and 20x8 up front looking for a tire that will fill the front up just looking for some tire sizes any recommendations I think I am going to run a 275/40 in the rear which is 28.7 inches tall did not know what the tallest I could put up front without any problems
blazercrazy70 is offline   Reply With Quote
Old 03-24-2014, 01:47 AM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: tire height
That is not all you have to consider. if you dont want your front tires rubbing when you turn Your tread width, 50-60-70-75 and rim width are factors as well.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-24-2014, 01:52 AM   #3
blazercrazy70
Re: tire height
I was looking at a 245/40
Old 03-24-2014, 02:09 AM   #4
Vova
Re: tire height
Are you stock or lowered? I run 245/40/20 on the front of my bagged truck without any issues.
Vova is offline   Reply With Quote
Old 03-24-2014, 02:15 AM   #5
blazercrazy70
Re: tire height
I'm going to drop it 3.5 in the front with drop spindles and lowering springs. What are you running in the rear? Do you have any pictures with your set up
Old 03-24-2014, 02:19 AM   #6
Vova
Re: tire height
Might want a little taller tire to help fill the well. Or go lower...
Old 03-24-2014, 02:30 AM   #7
blazercrazy70
Re: tire height
thanks for the help
Old 03-24-2014, 05:16 AM   #8
CC69Rat
CC69Rat's Avatar
Re: tire height
Measure the height of the truck prior to the drop.. maybe from the ground to the top edge of the fender lip. Then subtract about how low you want it to be.. 'Its here, but I'd like for it to be here'
That of course will be your drop but also remember your stock springs have likely sagged a little over the years. For example a 1" drop spring up front would likely not even drop your truck at all vs. the sagging stock springs.
What I'd suggest is measure, fender-to-ground compared to where you want it and add 1inch when you order your drop.
For your tires - width divided by 25.4 will give you inches. Say 255/40/20. 255/25.4 = the width of the tire overall. Now take this number and multiply by the aspect ratio. 255/25.4 * .40. This will give you the height of the sidewall. So, .. sidewall x2 plus the diameter of the wheel is the overall height of the tire.
275/40/20 = 10.826 " wide. 4.33" sidewall. X2+20 = 28.66
255/40 up front (?). 10.03 " wide 4.01" sidewall. 28.02" overall.
Your backspacing also makes a big impact on the overall fit and look of the wheels. What is the backspacing on the Show wheels?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-24-2014, 07:47 AM   #9
19GM71
19GM71's Avatar
Re: tire height
Here is mine. 3" drop front, 5" drop rear, 20x8.5, 245/45/20 all around. No issues at all.
19GM71 is offline   Reply With Quote
