Old 10-05-2014, 12:57 AM   #1
60ShortStepGMC
60ShortStepGMC's Avatar
Forward fuel line mounting clip
The forward section of fuel line on my truck runs from the front of the engine to a point near the rear of the cab. It's routed inside the frame rail.
There are two points where the fuel line is attached to the frame: one under the cab, one in the engine compartment. At both points it's attached with clips that poke through the frame with a spring loaded "M". Squeeze the "M" and pop it through the frame to remove it. Simple.
Except the one in the engine compartment is directly opposite my front suspension. Assuming it pokes through the frame, there is no access point that I can see in order the squeeze the "M".
Question is: what's the best way to remove that front mounting clip?
60ShortStepGMC is offline   Reply With Quote
Old 10-05-2014, 04:10 AM   #2
Kenfuzed
Kenfuzed's Avatar
Re: Forward fuel line mounting clip
I just encountered that blasted clip the other day and after a few minutes of fighting with it I lost all patience and ripped it out with a pair of diagonal cutters!
I'll figure out a replacement clip later.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 10-05-2014, 06:44 AM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
I've come to the conclusion that the "M" part of the clip is a one time only thing "install"
Pretty sure the factory used a punch to spread the "M" to hold the clip in .
Most of mine broke up when I took them out , and the ones that didn't I wouldn't trust to stay in if I reused them.
The brake lines have the same style of clip.
Like Kenfuzed did , rip it out !
And yes like Ken , I'll be figuring that one out later
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 10-05-2014, 12:55 PM   #4
60ShortStepGMC
Thanks gents. I was figuring rip'em out was probably what I'd have to do.
