Old 11-23-2014, 01:11 PM   #1
jpnh
jpnh's Avatar
LS swap radiator options?
Swapping an LQ4 6.0 into my c10 what's the best radiator/ place to deal with for my swap? Any help is appreciated.the old radiator is useable but slightly funky I'd rather invest in a better one with electric fans but not sure who to deal with/ the right configuration.looking for advice-Jeff
jpnh is offline   Reply With Quote
Old 11-23-2014, 01:57 PM   #2
mattcrp1
mattcrp1's Avatar
Re: LS swap radiator options?
I got a Griffin ls swap radiator for mine, I'm doing a 4.8l in my 76, its a nice radiator. I am having a little trouble mounting it though, I don't have the original radiator retainers and I am having to make some up. I know there is a vendor here on the board that sells radiators for this swap as well.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 11-23-2014, 04:13 PM   #3
jpnh
jpnh's Avatar
Cool I'll check m outgotta find a few and see what's the best fit for my situation I don't want cooling problems don't want to spend a bunch of money and get the wrong fit that's why I figured I'd ask here first beforehand
Old 11-23-2014, 04:45 PM   #4
Stepper86
Stepper86's Avatar
Hi.
Im also puting an LQ4 in my truck now
I went with Griffin. I only test fitted it so far, but measurements and fit looks ok.
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 11-23-2014, 07:56 PM   #5
jpnh
jpnh's Avatar
Originally Posted by Stepper86 View Post
Hi.
Griffin hmmm sent them an e mail to see what they might be able to come up with seen a few rigs using their components might be the way to go trying to weigh my options thanx for the input
Old 11-23-2014, 08:20 PM   #6
Malo83
Cruzzzn' Vet
Malo83's Avatar
Jegs has a nice setup
http://www.jegs.com/i/Be-Cool-Radiat...rentProductId=
Malo83 is offline   Reply With Quote
Old 11-24-2014, 10:27 AM   #7
Jonboy
Slots go on anything!
I used a new stock radiator and clutch fan. Mostly because I am cheap.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 11-24-2014, 01:50 PM   #8
bbbc10
Diggin The SquareLife
http://www.summitracing.com/search/m...-based-engines
if I was doing an ls swap I would use one of these and stock ls1 fans
bbbc10 is offline   Reply With Quote
Old 11-24-2014, 06:00 PM   #9
jpnh
jpnh's Avatar
Been lookin at the one with the trans cooler good price the review says it's 2 inches too tall think that's gonna be a pain? seems like a good deal I like the inlet is on the opposite side to get rid of the long top hose hmmm....
Old 11-26-2014, 06:47 AM   #10
jpnh
jpnh's Avatar
After much contemplation and research I'm gonna take bbbc10s and others (Matt/Tom thanx for weighing in.)advice and go with the griffin radiator I'm highly allergic to buying things twice so I appreciate the input I don't want any overheating problems my stock radiator is still good but is kinda funky not gonna chance it
Old 12-04-2014, 11:01 PM   #11
scottybaccus
scottybaccus's Avatar
You'll be much happier with a stock radiator, if you use a 2010 Camaro water pump. The waterneck is on the driver's side. It requires a minor relocation of the idler pulley. Dirty Dingo has a $26 kit to do that.
I used the 2010 Camaro pump, '05-'08 top hose, LQ4 lower hose, and H1 8.1L belt. My radiator is the OE 454 HD cooling option, with matching cushions and top plate from LMC. It's strapped down by a fan shroud I designed. Twin fans are from a LT1/LT4 Camaro.
Radiator was $140; Fans were pick-n-pull $20!!!; Top mount was about $40 with 4 cushions; Waterpump was $160, loaded with tensioner, pulley, thermostat and housing; Idler relocation bracket was $26; Top hose was $8; lower hose was $12; Belt was $35.
scottybaccus is offline   Reply With Quote
Old 12-05-2014, 06:04 AM   #12
jpnh
jpnh's Avatar
Wow,looks pretty clean nice work
Old 12-06-2014, 07:58 AM   #13
CHROMAHOLIC
CHROMAHOLIC's Avatar
PRC RADIATOR
CHROMAHOLIC is offline   Reply With Quote
Old 12-08-2014, 06:41 AM   #14
jpnh
jpnh's Avatar
Cool$$$$$
Old 12-08-2014, 02:30 PM   #15
solidaxel
solidaxel's Avatar
Originally Posted by CHROMAHOLIC View Post
PRC RADIATOR
Did your PRC radiator outlet fit your LS waterpump outlet?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-08-2014, 08:51 PM   #16
CHROMAHOLIC
it did so
Old 12-09-2014, 10:08 AM   #17
solidaxel
solidaxel's Avatar
They must have measured twice for yours !
LS 3 4L70E
