![]() Join Date: Jan 2015
Shop in San Diego to install LS motor
Hello all,
I am new to the forum and I am looking for a shop in San Diego to install a LS motor into my 1969 Blazer. My current small block 350 is done. Any help would be greatly appreciated. Thanks, Ryan |
Boosted Member
Re: Shop in San Diego to install LS motor
I have zero advice for you....but I'm morbidly interested in the quote you get when you find one.
Keep us in the loop.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
I did mine myself 4 years ago, a shop is SD will charge a ton to do this.
I could advise you on a few questions if you feel like tackling it yourself. Not hard at all as long as you have some technical abilities and can turn a wrench. |
Well I found a guy in San Marcus that would charge $2000-3000 for the just the install of the engine. The price I am getting for an engine swap is $8k-$11k.
72Mike-I am a little pressed for time and space to do the build myself. I do really appreciate the offer though. Thanks |
That price you were quoted, I think I should raise MY labor rates from the 60's to at least Y2K prices.....................damn I would have enough to stay retired
Did that price include engine and trans, and all fuel parts?
meowMEOWmeowMEOW
IMO engine swaps are something that you do yourself, or you don't do it at all unless; its a high-dollar ground up custom build (like a Riddler car or an actual turn key racecar) OR your doing something so radical that no home-hotrodder could attempt it.
Paying a shop to put a used engine into a used truck more often than not, results in getting the least bang for the buck, bar none. A typical LS swap is getting done under $4k, and that usually includes go-fast goodies and custom stuff. Your looking at over twice that for a stock junkyard motor. When something breaks, you have NO idea how to track down the problem if a shop did the work. You can't exactly have it towed to a normal garage if a failure occurs.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Jan 2009
PM me if you are interested in someone in Orange County I know a couple of shops that could do the installation
Pulatoy |
![]() Join Date: Aug 2004
RyKramer99,
I am a computer tech, I did my swap in my carport over a 7 month time frame, working evenings after my kids were in bed ( I am a single father also). The only thing I didnt do was the exhaust, I had a guy come out and do the exhaust on a trailer that was a lift kind of thing and he did my exhaust. I had very little help and rented the cherry picker and a few other tools I did not have. The engine and trans cost me about $1000, harness and tune, about $250, exhaust about $200, fuel and misc about $300. You can do this!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
2k to 3k just to install the engine??? I should be doing this for other people and not just myself.
CUNNINGHAM MOTORSPORTS is near san diego area. Ls1tech.sponsors. I went there and they had alot of nice cars being worked on including old schools getting ls swaps.
Charging that much money for an LS swap seems crazy to me. I did mine in about 2-3 weeks (4-6 hours a day). However I had all the parts that I needed from doing all the research before I started the swap. Converting the harness and intergrading with the existing truck harness was the hardest part.
I also agree with Brew, if something breaks you will know what is wrong and what parts to get. Auto parts stores won't know what to look for. |
