![]() Join Date: Dec 2013
4L80E pan hangs below frame
so im running all cpp stands/mounts/sliders/trans member and i peeked under the truck to see the trans pan hanging about an inch below the frame.
![]() options cuz she wont lay frame with that..... |
Re: 4L80E pan hangs below frame
You don't say what year your truck is, so It may or may not be helpful for you to know that the new Hooker 73-87 GM truck swap system leaves no components hanging below the frame rails.
Sorry.... 69
What is your trans angle at? You might be able to lift the trans a bit to get more clearance.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
you need pix of the pan hanging lower than the frame? lol i'll snap some tonight and get a rough measurement.
havent checked angles yet, but i need to soon so i can get my driveshaft shortened once my new spicer slip yoke comes in. im running all cpp stuff with the ES poly mounts....i guess i could call them and see if they might know roughly how the drivetrain sits. i do know....that if i have to raise the trans some....it'll be time for a high hump cuz i had to flatten the lip out to make the trans clear with how far back it is now. btw, hart_rod.....havent scanned enough to find a legit answer but suggestions on where to run the dbw pedal harness thru the firewall once your bracket is bolted in...which looks noice btw.... |
I used a aftermarket tubular cross member and had to use about a 2.5" spacer to get my drive line angle correct.
So don't get too upset until you get your angle set. I remember looking at my pan thinking "there is no way this is going to work like this"
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily ![]() |
oh im not upset. just something i noticed that would need to be addressed after i got the LS running....since dropmember and bags are the next step lol
