Old 09-18-2015, 09:07 AM   #1
solidaxel
solidaxel's Avatar
LS 3 amd 4L60E controller
I know the LS3 has its own ECM but what about the trans controller?
Where does the trans get its info, (TPS-VSS) what controller is available, and is there one better than the other ($$)
How does the cruise control work with this combo?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-18-2015, 09:28 AM   #2
Matt Cramer
Re: LS 3 amd 4L60E controller
You might be able to use a PCM from something that had a 58X crank triggered motor backed by a 4L60E. Maybe a 2005-2006 GTO?
Another option would be to use a standalone transmission control box. I'm running a MicroSquirt on my 4L60E with a home-brew harness (disclaimer: I also work for a company that sells them).
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 09-18-2015, 10:44 PM   #3
solidaxel
solidaxel's Avatar
I have a 4L60E in my 53 and a stand alone TCM BUT I have a Throttle Position Sensor on my Holley.
So how does the stand alone ECM connect to stand alone TCM for a TPS
LS 3 4L70E
Old 09-18-2015, 10:51 PM   #4
Advanced Design
Advanced Design's Avatar
Don't know that stand alone systems will communicate with each other unless they were designed to. To get TPS input for both systems this should work.
http://www.tciauto.com/tc/electronic...-y-harnesshtml
Advanced Design is offline   Reply With Quote
