Old 11-12-2015, 06:25 AM   #1
Shortbed 68
ls swap
Any useful info welcomed on ls swap in a 68 short bed. As for radiator, trans cooler, wiring, Drivetrain, fuel system with stock in cab tank, anything helpful thank you
Shortbed 68 is offline   Reply With Quote
Old 11-12-2015, 08:25 AM   #2
jessemthompson
Re: ls swap
All the information you're looking for is over in the LSX swap section. I just finished my swap last spring. Best thing I've done to the truck.
jessemthompson is offline   Reply With Quote
Old 11-12-2015, 11:16 AM   #3
Matt Cramer
Re: ls swap
As noted, there's an LS swap section here:
http://67-72chevytrucks.com/vboard/f...play.php?f=206
But I can give some quick answers to your questions.
Radiator: I used the stock one, with 2005 Silverado hoses.
Trans cooler: The one in the stock radiator works unless you're doing something crazy (or have reason to suspect it's full of crud).
wiring: Lots of options here. You can run an aftermarket standalone ECU (that's what I did), run a stock ECU with a professionally made engine swap harness, or a stock ECU and mod the harness yourself, depending on your needs, skills, and budget.
Drivetrain: If you want an automatic, a good option is to get the engine with its matching 4L60E or 4L80E transmission as a set. You'll have to modify the driveshaft to make it fit. You can get just about any transmission that fits behind a small block Chevy to go behind an LSx if you want.
Fuel system with stock in cab tank: Yes, it's doable; I stuck a Walbro 255 lph fuel pump intended for a Mazda Miata in my stock tank. If I did things again, though, I'd use a tank mounted under the bed as I still sometimes have a gas smell in the cab and I don't like that. Plus, an electric in tank pump is pretty loud - a pump under the cab would probably have been a better choice, but I wanted to see just how easy a low buck in tank fuel pump conversion would be.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 12-03-2015, 10:19 AM   #4
SparkyRnD
SparkyRnD's Avatar
Re: ls swap
We make bolt-in conversion radiators and we also offer a forum member discount:
http://67-72chevytrucks.com/vboard/s...d.php?t=590670
We can build it for any engine set-up including the LS (no additional charge) and include a free steam port and built-in trans cooler if needed.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 12-03-2015, 11:14 AM   #5
trkfrk
trkfrk's Avatar
Re: ls swap
Another good place to research are the build threads. There are a ton of great LS builds going on right now. Good luck.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 12-03-2015, 03:20 PM   #6
gottattooz
gottattooz's Avatar
Re: ls swap
http://67-72chevytrucks.com/vboard/s...d.php?t=468341
Here's my build thread for my 68 short/wide.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
