Old 07-03-2014, 05:15 PM   #1
Newfie71
Newfie71's Avatar
upper ball joint
hey Guys im in the process of installing my new mcgaughys spindles , but seem my upper ball joint wont fit. is it the wrong ball joint? lower works fine.
wayne
Newfie71 is offline   Reply With Quote
Old 07-03-2014, 05:21 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: upper ball joint
The spindles and the balljoints must match.
What year spindles and what year balljoints?
Keith
Convert to disc brakes.
Old 07-03-2014, 05:25 PM   #3
Newfie71
Newfie71's Avatar
Spindles are marked 60-72, have proforged ball joint 101-10037 which is for 1970.
Old 07-03-2014, 05:26 PM   #4
Newfie71
Newfie71's Avatar
the ball joint goes into the spindle but not enought to get nut on . do i have to press together seem tapers dont match ?
Old 07-03-2014, 05:28 PM   #5
lolife99
lolife99's Avatar
Spindle break down as follows:
60-62
63-70
71-72
73-87 Light Duty
73-87 HD
If the upper doesn't match,... neither will the outer tie rod.
You have to figure out what spindle you have.
Keith
Old 07-03-2014, 05:29 PM   #6
lolife99
lolife99's Avatar
Where did the spindles come from?
Keith
Old 07-03-2014, 05:30 PM   #7
Newfie71
Newfie71's Avatar
Mcgaughys spindles
Old 07-03-2014, 05:32 PM   #8
Newfie71
Newfie71's Avatar
its all for a PB dropmember , ordered all for azproperfomance.
Old 07-03-2014, 05:33 PM   #9
lolife99
lolife99's Avatar
Originally Posted by Newfie71 View Post
Mcgaughys spindles
If your truck is a 1970.
You need a 63-70 conversion spindle.
I don't know what else to tell you.
Maybe your balljoint was boxed wrong.
Does the outer tie rod fit?
Keith
Old 07-03-2014, 05:34 PM   #10
Newfie71
Newfie71's Avatar
my truck is a 1971 .
Old 07-03-2014, 05:35 PM   #11
Newfie71
Newfie71's Avatar
i think i got wrong ball joints
Old 07-03-2014, 05:35 PM   #12
lolife99
lolife99's Avatar
A 1970 C10 truck requires a McGaughy's 63173 spindle.
Is that what you have?
http://www.summitracing.com/parts/mm...del/c10-pickup
Keith
Old 07-03-2014, 05:36 PM   #13
lolife99
lolife99's Avatar
Ok.
I guess a little more info in the first post would have help me get you an answer quicker.
Forget everything I posted.
Keith
Old 07-03-2014, 05:46 PM   #14
Newfie71
Newfie71's Avatar
sorry , i have a 1971 c10 stepside , installing drop member , have mcgaughys spindles 63176. no marking on spindles but thats what says on order sheet. i have proforged ball joints , lowers are 101-10036 uppers are 101-10037, lowers are fine , uppers not .i looked up numbers and i see that 101-10037 is for 1970 , so most likely that was my problem.
sorry for confusion i was at it in my garage, on phone. lol. thanks for your response
Old 12-19-2015, 11:40 AM   #15
1IR872
1IR872's Avatar
I have a '72 and just went through this, went to three different auto parts stores. All the upper ball joints I tried did NOT go through the spindle far enough to get the nut past the cotter pin hole on the originals or the new drop spindles.
Then I went to NAPA and bought the NAPA brand ball joints from them that fit perfectly.
I think there are different ball joints made by different companies that try to say they are for our trucks but just don't have the right measurements. They try to be the one set for all but just don't cut it and end up being junk and causing us a lot of misery.
Don't go cheap! Get the expensive ones and you will be happy.
1972 C-10 Custom Deluxe 468 BBC w/ TCI 400 Trans
1987 GMC Jimmy Sierra (New project)
1IR872 is offline   Reply With Quote
