Dirty dingos mounts
Currently working on a 78 short bed 2wheel drive with a ls1/4l60e equipped with dirty dingos engine sliding plates. My question is how far back did you guys go if your using these plates? My stock driveshaft fits well but I see from my yolk that I could go further back more, and on the plates I see little more room to play with so slide back. Thank you guys in advance... also added a picture of the passenger side plate
![]() Join Date: Apr 2005
Re: Dirty dingos mounts
I would go as far back as you could. This will give you a better weight distribution front to rear. Just make sure you have no interference with your headers or your intake.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I have taken all three I have done as far back as possible. Makes more room up front too.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
Thank you guys for the reply s and advice...
COOPERHW; when moving all the way back did you have any type of modifying when connecting shifter? Im using a 4l60e. Also Im using f-body long tube headers what did you use?thanks |
#5 | |
I am using stock F-body exhaust manifolds.
