Junior Member
![]() Join Date: May 2014
1 of 1 truck?
I finally found a 4x4 longbed stepside that isn't rusted out. I know these are rare, but this is the only one I've seen with these options. I have found breakdowns of the year and model but none with option lists... Any help would be apreciated.
Its a 1970 cst-10 4x4 long stepside with the 350, factory air, marker light cab (only c10 I've seen with them) and she's hugger orange. Posted via Mobile Device |
Vintage 4x4s
Re: 1 of 1 truck?
With paint that looks that nice its either a very nice survivor or a truck thats been redone. If its been redone, it may have been reconfigured to be a CST with air, lights, stepside, etc. Is the SPID there? That would tell you what it was, unless it too was redone.
If it really is original, yes its a rare truck to be configured like that, only about 10% of trucks were 4x4 in 1970. Then only a fraction of those were CST's, and only a fraction were stepsides.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
All about them K’s
![]() Join Date: Jun 2014
Re: 1 of 1 truck?
I've only seen one other half ton with marker lights. My dad had a 71 k/10 custom lwb that had the markers when I was a kid. That is a real nice find man. You can't beat hugger that's for sure!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Re: 1 of 1 truck?
SPID = Service Parts Indentification Decal. Should be located inside glove box door. This helps learn the factory history of the vehicle. Longbed stepsides are super functional and often under appreciated, condition trumphs configuration, in my book.
Junior Member
Re: 1 of 1 truck?
Its original paint, I'll post the spid in a bit. Its a very nice original out of nevada. Seat has been recovred but that's about it. I'm looking to see if there was ever another one like it or if it is truly a 1 of 1. I wasn't told that it was, but I believe it to be and just want to make sure if at all possible
Re: 1 of 1 truck?
I've seen several 1/2 tons with marker lamps. I have said on here before my brothers and all their friends it was a rage back then to have them it must have been a local redneck type thing fore this isolated group. but to them the roof lamps was more sought after than say a tilt column or FM music. I remember one in particular it was hugger white hugger and white with roof lamps and tilt. I think my brother had that one and loved it dearly. Jim
Currently Blazerless
Re: 1 of 1 truck?
There is no way to break down production numbers by options. I've seen several 1/2 tons with factory marker lights, I would say it's less common to see a long bed stepside CST. Most I have come across were plain Jane trucks, usually ordered by farmers back in the day.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Junior Member
Re: 1 of 1 truck?
That's why I'm wondering if it is a 1 of 1 truck. From my research less than 1,000 Long stepsides were 1/2 ton 4X4's and most would have been base models. To have it be a CST-10 with marker lights and this color, I know it is very rare and possibly a 1 of 1, but would like to confirm it if possible. Here are some more pics, she was well cared for.
Junior Member
Couldn't shrink the files so I took a pic with my phone...
Junior Member
![]() Join Date: Jun 2011
Re: 1 of 1 truck?
I do not believe there's any surefire way to verify that there was never another built just like that. Awesome truck though!!!! Dual spots too!
Re: 1 of 1 truck?
While it is a rare combination of options you will never be able to prove its the "only one". Even if you were it adds about zero to its value.
To some extent most optioned up heavier (20-30) or 4x4 trucks are rare if you try and break it down to individual option combinations on specific models. Less so on the more personal sized 10 series. While a CST stepside is a rare beast I dare say you are much more likely to see the option on a CK10 than say a CK20 or C30. As examples: Is this Black K10 CST more rare? Probably if you factor in the optional half lower bodyside molding. But does it's factory block heater trump A/C? Maybe the CST/30 stepside buried in my data collection with a 396 close ratio four speed and A/C is a "1 of 1". Probably is if you consider the 503 green paint or buckets seats too. The point is there are many variations of models and RPO options. If you were to try and include the service options as well there are many with very unique builds.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: 1 of 1 truck?
That is truly a rare truck. It is true there's no way to prove if it is one of one. It very well may be. I would bet it is very possible that is the only truck in that color with those exact options. There was just no break down on options
![]() Join Date: Dec 2013
Re: 1 of 1 truck?
The sad part is a short bed will sell for more money everyday .no matter what options or paint it has .
#15 |
All about them K’s
Re: 1 of 1 truck?
I couldn't agree more it's very sad to me.
#16 |
Re: 1 of 1 truck?
Only sad if you are trying to buy a SWB or sell a LWB.
Perfect if you are buying a LWB 4x4! |
#17 |
Born Psycho
![]() Join Date: Feb 2001
thats the first CST longbed stepside i've seen. i've seen plenty of shortbed stepside CST's, cheyenne and cheyenne supers over the years but never a long stepper, especially a 4x4 version. very cool truck.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#18 |
Old Duffer
![]() Join Date: Mar 2003
Re: 1 of 1 truck?
I don't know if they still do it, but try "Chevrolet Customer Assistance Center" at 1-800-222-1020. They were/are in Troy Michigan. They will want the VIN of your truck. They will not be able to tell you specifically about your truck, but can give you an idea as to it's rarity.
I called them several years ago about my truck and was told that in 1968 Chevrolet did not keep track of anything that was 1% or less of a production run. I don't know what the parameters were for '70. I'm saying this because if the rules didn't change, and there were 1000 long step C10's built, the closest you may come to knowing would be "1 of 10 or less". Even that's not too shabby!
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
#19 |
Junior Member
True today...not necessarily tomorrow. These long step 4x4's are getting very hard to find. A lot of people I meet today haven't seen one before. They were rare to start and many have been converted to short steps, etc. Besides I think the long steps give a lot more utility and look better when lifted, just my opinion.
#20 | |
Junior Member
Gentlemen, Thanks for all of the help and other cool truck pics. I really appreciate the info!! |
#21 | |
Junior Member
#22 |
Re: 1 of 1 truck?
If I found that truck and the guy would sell, I would try hard to buy it.
#23 |
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: 1 of 1 truck?
Beautiful truck. A pox upon whoever put the air horns on the roof...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#24 |
Re: 1 of 1 truck?
This all depends on who is looking to buy. Although the bulk of the herd only care for a shortbed, there are those who like what they like despite the herd, or just know their trucks and what is or isn't rare. A true truck guy loves them all because they are all trucks. There are shortbed guys (usually car converts) then there are truck guys (usually like shortbeds as cars). A real truck guy would pay for the rarity, now, yesterday, and especially tomorrow. And long Stepside 4wds are just plain cool
#25 |
Re: 1 of 1 truck?
Since I am still trying to track this truck down again, here it is once more.
