Lower Control Arm Drags Ground after drop
I just finished my 78 Blazer and drove it for the first time last night. 2 biggest things are the lower control arm scrapes the ground on any bump larger than a leaf, and the tires rub the fenders pretty bad. Drop is a 2.5" spindle with a 2" spring. My LCA is 2.75" from the ground. That just seems really low to others on here that I've been looking at. If I swap to a 1" spring will that raise my arm to 3.75"? Or what's the best way to get some more clearance? My fender to ground measurement is 24.75" at the center of the tire..
Diggin The SquareLife
Re: Lower Control Arm Drags Ground after drop
you can raise it up or get some lower control arms
But does it look lower than other trucks? Just trying to figure out if this is normal or i've got something weird going on.
yeller
people do 4-5" front drops all the time. I have had 2 trucks, and never had any issues. Something is off. I would think with those tall fronts, you would have fender rub but not LCA issues.
What brand spindles and springs?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
driving is in my blood
Both my 78 and my old 79 were 5" drop in front using 2" springs. Yes, the control arms are close to the ground. But its never been an issues EXCEPT once, crossroad was raised a good 2-3" inches from ours from construction and its really smashed them good. Otherwise I've put 50,000+ miles on the setup with never an issue......
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
I have 3" spindles, and 1-ton coils cut until the 235/70R15 tires are even with the top fender edge (about a coil and a half - so.... 2 or 3 more inches?).
I cannot slip a 2x4 on edge under the control arms, but I have never hit anything with them. ![]() Mind you, I've been driving lowered vehicles for years. I have one vehicle where the lowest point is 1-1/2" off the ground.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Post up a ground view picture from the front looking at the control arms. It looks low, but not low enough to be dragging control arms. Are you sure that they are dragging?
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
#8 | |
This is a picture of the underside. I know it's not a good one but that lowest part of the arm is 2.75" from the ground. Thinking of getting some heavy duty shocks too to try and help? What shocks are you guy running? ![]() |
Shocks won't help the ride height any; they don't hold up the vehicle.
I run stock, cheapie, Monroe blue.
What is the front tire size?
Maybe a larger diameter tire would be easier?
I agree. Was just thinking it wouldn't drop down so much when I hit bumps. That's all.
Posted via Mobile Device |
I have a 78 c10 short step 2wd. I assume the entire front end is the same as your truck. I have 2.5" spindles and 2' springs too... i used whatever the standard size equivalent tire to stock is on a 6.5". My control arms look parrallel to the ground, but they have never touched anything. my tires...however...are always bumping into the inner fenders...They make a loud ass thud that startles me everytime.
I have the same drop on my 74 done by the previous owner I just measured my arms I have 3" clearance with 17's on low profiles. If I go to fast sometime my arms drag as well.
How about you sell me the blazer and I'll worry about the control arms
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
#15 |
I had 5" drop in the front also an my controls dragged the ground
#16 |
#17 |
#18 |
What is your front tire size?
#19 |
67-72 parts collector,…
![]() Join Date: Nov 2002
This is all perfectly normal with the drop you have.
That's why the Porterbuilt extreme Dropmembers are so popular. You gain 3" of ground clearance over what you have at that ride height. That's your best bet to gain ground clearance. They make a NICE coil over setup for people that don't want bags,...
#20 |
#21 | |
#22 | |
But that won't help. This crossmember saddle is still the mounting point for all tubular a-arms as well. Ground clearance will be the same.
#23 |
No i ended up totaling the frame due to the control arms getting caught on rail road tracks and it threw my truck up in the air an it slammed back down...it bent the frame under the cab an cracked the frame behind the front left shock an the twisted the whole front to the right.....so i got thorbros front crossmember mmw arms an ekstensive rear kit to bag it
#24 |
I was thinking that if the center line of the arm is now raised and in line with the bushings that would easily add 1.5" to the ground clearance, if that makes sense.
#25 |
Your tires are a good 3" shorter in diameter than mine. Which (by radius), means you'd have an inch and a half more clearance with taller tires.
