Old 08-22-2016, 02:58 PM   #1
cfan10
cfan10's Avatar
Cool 96-99 5.7 vortec?
Is it possible to carb a 96-99 5.7 vortec with just adapter plate for the intake, or does the intake need to be replaced as well?
Will this engine drop in an 84 c10 without changing the motor mounts?
Is it possible to mate it to a th350 transmission?
Can the front assembly from 96-99 Chevy truck
Crossmember/control arms/spindle/tie rods/sway bar bolt up to an 84 c10 frame without major modification or fabrication?
What I have on the c10 I want to keep since these parts aren't even a year old. What will I need to do to make that happen? I know the alternator is different. As always thanks in advance for your help/experience.
Edelbrock 1406 carb
Msd pro distributor
Msd starter
Pro comp alternator
Edelbrock valve covers
Accel coil
Msd wires
Mr. Gssket electric fuel pump
How much approximately am I looking at for this swap. I can get the engine at the junkyard for about $200.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 08-22-2016, 03:39 PM   #2
Nick_R_23
Nick_R_23's Avatar
Re: 96-99 5.7 vortec?
You can keep and reuse everything you have on your list with a Vortec motor. You will have to change the intake as an assembly to a carb conversion intake. I'm doing this exact swap on my truck with a Weiand Street Warrior 8121. It's still a small block Chevy so it will fit any regular SBC transmissions. You will need a 1 piece rear main flexplate though, but that should come with your Vortec engine. Valve covers may or may not swap depending on what bolt pattern you currently have.
Edit: Engine mounts are the same, just reuse the mouths off your '84. You can reuse your alternator/belt drive off the '84 too, but I'd recommend using the serpentine setup off the Vortec as its a much better system than the old v-belts.
Old 08-22-2016, 08:43 PM   #3
Tom
driving is in my blood
Tom's Avatar
Change the intake for carb and timing cover because it has a hole for a crank sensor. Tada, your done. Vortecs are standerd small blocks. No, 88-98 suspension does not bolt onto 73-87's.
Old 08-22-2016, 11:28 PM   #4
bark
Don't forget the distributor gear, vortecs have a roller cam, and don't rollers usually require a bronze gear??? I know the vortecs have a different style cap.
Also no spot for a mechanical fuel pump.
bark is offline   Reply With Quote
Old 08-23-2016, 06:12 PM   #5
Tom
Tom's Avatar
Good call. Standerd distributor bolts in no problem, but you need a melonized distributer gear from GM. No idea why bronze is still out there, it was never oem. It has the pad for mechanical pumps but the pushrod hole to work the pump is not drilled and the cam has no lobe to operate the pushrod. A drill and cam swap would make it work if your really into mechanical pumps for some reason.
Old 08-23-2016, 10:23 PM   #6
RootBeerFXS
RootBeerFXS's Avatar
You could leave the timing cover if you don't mind the crank sensor being there. I did find out the hard way that the cover will not allow the use of your stock power steering pump bracket. I went with an aftermarket bracket set up.
RootBeerFXS is offline   Reply With Quote
Old 08-23-2016, 10:35 PM   #7
bark
Could you rob the gear from the vortec dist. And put it on an hei?
Old 08-23-2016, 10:40 PM   #8
bark
http://www.superchevy.com/how-to/678...cam-355-build/
And you need a hot cam kit. I bought one years ago, before I was more interested in lsx swaps, and it's still sitting in my basement Incase I get a chance to build my vortec.
Old 08-24-2016, 05:27 PM   #9
cfan10
cfan10's Avatar
Cool Re: 96-99 5.7 vortec?
Thanks for all the advice guys!
I was asking about the motor mounts because my crossmember has some hairline cracks, and a friend is parting out a 98 truck with drop spindles and springs control arms. I'll have to get the engine at jy on sale day because he's keeping his for his other truck.
Anyhoo, when checking jy engine...
Try to find a wrecked vehicle, astro van/1500 truck/suburban/tahoe thinking that the vans are probably less worked and worn than the others.
Check oil
Remove valve covers
Turn damper by hand
Remove #1 spark to check for compression on tdc
Thinking easiest thing is to try to start it, but with remote starter have to sneak battery in as lkq doesn't want you to start them, also if gas tank isn't there how can I start a vortec?
Try to remove oil pan or cut some of it out to check the pan for metal shavings. I have a few extras in storage.
Came across a 4.3 v6 TBI engine pulled from an '89 s10 would this work in an 84 swb and save gas?
