no spark how to trouble shoot coils?
2008 5.3 engine will not start but, it does turn over and I have 80psi at the fuel rail when cranking, I checked for spark and nothing, how do I trouble shoot the coils? Should I pull the fuel rail along with the injectors to see if they are all spraying? Any help greatly appreciated.
![]() ![]() Join Date: Oct 2011
Re: no spark how to trouble shoot coils?
Did you check the ignition fuse?
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
I checked all the fuses, they are good.
meowMEOWmeowMEOW
Take a look at the harness that branches off of each coil on to the main leg. Those wires can occasionally get pinched, pulled, or broken (usually when the valve covers needed to be accessed, the coils all get moved, and the harness gets damaged).
Do you not get spark on ANY of the leads, or just on a few? If you don't get spark on anything, its usually not the coils to blame.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I used my old school timing light on my 2002 Toyota individual coils and it lights just a bunch of times instead of just once like the old gen 1's. I was able to locate the bad coil as it did not make any lights at all. I just clamped the plug wire clamp to the small wires going to the coils.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#6 | |
![]() Join Date: Jul 2009
ok so I checked all 8 coils going to the pink wire on each one of the connectors and they are all getting 12volts but, I checked the black wire on all 8 for chassis ground and nothing. I think I missed one of the grounds on the harness but I can't find it.
My harness had 3 ground wires that are tied to the block
The ground for the coils is usually behind the power steering pump, on the left lower side of the block.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
well well well what do we have here.....
I'd say a ground that wasn't hooked up....
She fired right up but, the throttle is not responding, I think it's because I'm running a 2008 Impala pedal. Also I'm getting a misfire, I'm going to check the injectors.
Swaped D and F pins on the pedal connector and that did it, I'm getting instant throttle response. I erased the p2138 code hope it don't come back.
Congratulations!
#15 |
Thank you Craig.
#16 |
^^^^^ wtf?????
#17 |
YES !!
First post too! I am sure there is a very good explanation for this................. maybe not!!!!
#18 |
Its spam and has been removed. That person or robot will be removed from the site shortly.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#19 |
Am I missing something???
#20 |
Apparently you didn't see it, but there was a post that was like a hunderd lines or so, it was loooooong, something about football players or something, didnt read it all but it didn't make any sense to me.
#21 |
Just wanted to thank everyone for your help, I got more input here than any other site, well maybe LS1TECH was helpful also, Ls1Nova would always respond to my novice questions. Took her out for the 1st time and it seems like I might have a vacuum leak, it revs really high when I'm at a stop.
