driveshaft lenght on a v8 ... ?
hello all,
would anyone knowing a driveshaft length with using a 700r4 on a v8 on a 66 ( original setup v8 w/ power glide )
dont want to hear excuses, i want to hear solution(s) |
![]() Join Date: Jan 2011
Re: driveshaft lenght on a v8 ... ?
Depends on what what length tail shaft is on the trans. Short bed or long? I prefer to take actual measurements so I know it will fit when I get one made.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
long bed also could the current transmission mount be modified to accept a 700r4 ( with replacing the rubber mount bushing ) or an aftermarket one is needed ... ?
you may have to move the crossmember back a bit to match up for the mount. here are the dimensions
http://chevellestuff.net/tech/automa...dimensions.htm ron |
