Old 09-04-2012, 05:43 PM   #1
missinfishin10
Amazed Member
missinfishin10's Avatar
Upper Door Hinge Friction Pad Repair
I hated that my doors wouldn't stay open while i was working on the interior. I was propping it open with anything. This afternoon I had had enough! I drove the roll pin out of the upper hinge and removed the arm and the 2 pads. Pondered it for a bit, cleaned them up, pryed the pads out and turned them both over. Then I spread the arms out a little with a screwdriver and a hammer and re-assembled. They work like a champ. Doors stay open from about halfway out and closed on there own less than that. This was a BREEZE! Took less than an hour for both doors and works great, hopefully for a while!
Sorry I didn't take any pics.
Take care!
Jeff
71 LWB Fleetside
1950 3100 Original Project!
missinfishin10 is offline   Reply With Quote
Old 09-04-2012, 08:08 PM   #2
AirSpeed
AirSpeed's Avatar
Re: Upper Door Hinge Friction Pad Repair
I have the same problem, about ten years ago I bought some replacement pads from the then Chevy Duty, now Classic parts but they don't seem to sell them anymore. I've been looking for something made of a similar material to use with no luck. Mine are simply worn out, not enough material left to make turning them over possible. Anyone know of a supplier that sells only the pads? By the way, did you do this by yourself or with help? If you did it by yourself how did you keep the door from falling while the pin was out?
AirSpeed is offline   Reply With Quote
Old 09-04-2012, 08:27 PM   #3
JimKshortstep4x4
I have repaired a lot of the door stops with good results. I use brake pads as a material to make the pads out of and then glue the pads in with 3M Trim Adhesive. The pads last a very long time and I have not worn any out yet after years of use.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-04-2012, 08:33 PM   #4
missinfishin10
Amazed Member
I was all alone!
Don't drive the actual hinge pin out, just the arm that goes though the friction pads into the door. Hang on, I'll go get pic... ok attached...
The arm has to come out from the inside of the door.
71 LWB Fleetside
Old 09-04-2012, 09:19 PM   #5
AirSpeed
AirSpeed's Avatar
Originally Posted by missinfishin10 View Post
I was all alone!
Thanks! For some reason I was thinking of the actual hinge pin.
Old 09-05-2012, 06:31 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
For my driver truck, I just spread the metal apart on the arm to make it contact the friction pad. Took .48 seconds.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-31-2017, 06:40 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Nothing like reviving an old thread! Tried to drive out my roll pin as shown in post #4 above. No joy, that sucker has not moved in 46 years and is not gonna give up easily. Soaked it with penetrating oil and will try again later. Pads are shot and I've already tried spreading the two arms apart. I'll let ya know if I ever break that stubborn pin loose...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
