power steering hose question
Hey all, I am in the process of doing an LS swap (2010 5.3), and currently have manual steering. I will be upgrading to power steering at the same time and need help determining the correct pressure and return hoses to use. I have a 1970 C10 power steering gearbox (remanufactured by Cardone), and the 5.3 already has a pump on it. Will these hoses work?
https://www.speedwaymotors.com/Unive...hoCgboQAvD_BwE Thanks |
meowMEOWmeowMEOW
Re: power steering hose question
The LS steering pump is metric. The steering gears were SAE and a few went metric later in production.
You'll either run a line with the correct ends, or you may be able to swap the fitting on the rear of the steering pump. There are a few threads about doing so in this section.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#3 | |
https://www.dirtydingo.com/shop/mobile_product_info.php?products_id=1414 Posted via Mobile Device |
![]() Join Date: Aug 2004
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Sep 2005
The easliest way i know to do this is go to the junk yard find an old chevy early 70s to late 70s and steal the 1 inch fitting and spring and vavle out of it then swap it to the new ls pump and use the stock lines for you truck thats what i did on my 71 c10 that why if hose ever breaks i can just get on at the parts store
Look at this thread http://67-72chevytrucks.com/vboard/s...d.php?t=627585
#7 | ||
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
