Old 12-27-2018, 08:15 PM   #1
Dodge68charger
Wood Bed Floor Questions?
Where Did Everyone Get Their Wood Floors From? . Looking To Go With Pine. Seems The Cheapest Option and what Did You Use To Finish It..
Dodge68charger is offline   Reply With Quote
Old 12-27-2018, 08:33 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Wood Bed Floor Questions?
Member GR8-68 , He made me 2 sets 1 Ash and 1 Black Walnut . Very nice job . The Ash is going in a lt green 67 short bed , I plan to thin the paint enough to use it as stain and then clear coat it to a mirror finish . I just wiped it with a damp rag to show the grain .
Old 12-27-2018, 08:55 PM   #3
Dodge68charger
Looks Good!!
I Have The Capabilities To Make Them. Just No Measurements For a
69 Swb Fleetside. Im Sure Home Depot Should Have Some pine.. i Hope lol
Old 12-27-2018, 08:56 PM   #4
jeffahart
jeffahart's Avatar
I used the southern yellow pine from classic parts(not classic industries) it was B better. Cheap and already dadoed. It has tight grain and is cheap. I used tung oil on mine. I do use my bed hard at times, and the truck is an outside dog.
Here's a post I did when I replaced my wood.
http://67-72chevytrucks.com/vboard/s....php?p=7657989
j
White K20
jeffahart is offline   Reply With Quote
Old 12-27-2018, 08:58 PM   #5
Dodge68charger
Thank You
Old 12-27-2018, 09:06 PM   #6
'69C-10
I used old barn board. Ran it through a planer, table saw then 3 coats of clear.
'67 C-10 SWB
'18 Sierra Denali
'18 Volvo XC90
'69C-10 is offline   Reply With Quote
Old 12-27-2018, 09:54 PM   #7
C-cab23
C-cab23's Avatar
I have these measurements that saved for when I do my floor...I hope this helps
1968 GMC stepside long bed
2004 GMC Yukon
2004 Chevy SSR
1969 Chevelle SS
1946 Chevy 4 door sedan
1923 C-Cab
C-cab23 is offline   Reply With Quote
Old 12-27-2018, 09:56 PM   #8
C-cab23
C-cab23's Avatar
More specs
2004 GMC Yukon
2004 Chevy SSR
1969 Chevelle SS
1923 C-Cab
Old 12-27-2018, 09:59 PM   #9
C-cab23
C-cab23's Avatar
One more
2004 GMC Yukon
2004 Chevy SSR
1969 Chevelle SS
1923 C-Cab
Old 12-27-2018, 10:05 PM   #10
flashed
Does anyone of these places predrill the holes for bolts and washers .
flashed is offline   Reply With Quote
Old 12-27-2018, 10:13 PM   #11
panhead59
Mar-k out of ok city
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 12-27-2018, 10:45 PM   #12
AussieinNC
Moderator
AussieinNC's Avatar
PM GR8-68 ...he might be able to help you with the 4 bolt hole positions that need to be drilled.
The wear strips do not need bolt holes thru the timber boards.
BTW...be wary of big box store pine....being in Washington you should have ready access to decent milled pine....
Remember the wear strips need rebated grooves cut in them for the wear strips to locate into.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 12-27-2018, 10:51 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Southern yellow pine is a ton better than the pine you will find in a BORG store. It'll rot in a sickening hurry, unless you are protecting it from the weather.
~Steven
Simi Valley, CA
Old 12-28-2018, 09:07 AM   #14
panhead59
The clear needs to be a true spar varnish for max durabilty/longevity. Spar varnish is marine grade with extra uv filters. Its not that easy of a job to reclear so use the good stuff and it'll last longer. Polyurathane clear from lowes won't last. I use Epifanes high gloss. Find it on web. Not cheap at about $30 a quart. Takes about 2 qts. To do it right.
Old 12-28-2018, 10:59 AM   #15
davepl
davepl's Avatar
I spent weeks on my bed! I'm not a carpenter. I used Marine Spar varnish as panhead says. I believe got my wood from Mar-K? Wasn't cheap, but was good wood.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-28-2018, 03:46 PM   #16
biketopia
Don't forget to seal the underside of the wood!!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 12-28-2018, 08:12 PM   #17
72longstepper
Where in WA. are you I am in Carnation and just started on my "72 GMC.
72longstepper is offline   Reply With Quote
Old 12-29-2018, 01:18 PM   #18
darrellyates
On Mar-K's website, they have a pretty detailed test of various finishes used on wood bed floors. They tested everything including automotive clear paint, urethane for wood (Spar type), up to and including POR 15.
I used a product I found recommended on this site from KBS Coatings. It's called Diamond Coat clear coat. It's a epoxy, like POR 15 (which tested great on Mar-K's test) but is clear, UV stable, and developed for outdoor use.
Like others have said, I coated both sides, in the grooves, and the ends. You want a complete seal of the board.
I think it looks pretty good....
Best of Luck!
darrellyates is offline   Reply With Quote
