Old 09-05-2019, 01:17 PM   #1
daveshilling
daveshilling's Avatar
Let's see your favorite rear fuel tank filler options
As I get closer to making this pile of parts look like a truck, I need to get a rear tank going. Filling through the bed seems easiest to manage, but there are many cool options. Post your favorites below!
daveshilling is offline   Reply With Quote
Old 09-05-2019, 01:20 PM   #2
daveshilling
Re: Let's see your favorite rear fuel tank filler options
Cool through-the-bed option made to blend in:
Old 09-05-2019, 02:51 PM   #3
MiraclePieCo
MiraclePieCo's Avatar
I dig the magnets ^^^
Here's my panel access to under floor filler neck.
PS: Don't worry folks; the filler neck is not inside the cargo area, just the door to access it below the floor.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 09-05-2019, 04:37 PM   #4
b-mac
b-mac's Avatar
I just order this one. Came in last night. Looks sharp.
http://www.tanksinc.com/index.cfm/pa...rod/prd475.htm
b-mac is offline   Reply With Quote
Old 09-05-2019, 04:53 PM   #5
idbeast
Mines in the fender.
idbeast is offline   Reply With Quote
Old 09-05-2019, 06:22 PM   #6
daveshilling
Looks clean!
Old 09-05-2019, 07:57 PM   #7
bosco
bosco's Avatar
We went with a fairly simple filler.
bosco is offline   Reply With Quote
Old 09-05-2019, 11:13 PM   #8
Black_Sheep
Black_Sheep's Avatar
From the local marine supply...
Black_Sheep is offline   Reply With Quote
Old 09-06-2019, 02:21 AM   #9
MiraclePieCo
The '50 pickup I did. The other plate is a battery access cover.
Old 09-06-2019, 09:29 AM   #10
mgchevyparts
mgchevyparts's Avatar
On my 1940 Ford. Both stainless inserts are flush with top of wood.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 09-06-2019, 03:38 PM   #11
BAM55
BAM55's Avatar
I put mine in the stake pocket of my fleetside.
BAM55 is offline   Reply With Quote
Old 09-07-2019, 09:15 AM   #12
my56chevytruck
my56chevytruck's Avatar
Since my suburban gas tank's fill neck bends to the right of my rear truck fender, I bought a Harley Davidson gas cap and mounted it to the right rear fender. It mounts flush, pushes in and screws tight.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 09-08-2019, 02:13 PM   #13
_Ogre
_Ogre's Avatar
similar to idbeast, truk has the filler door in the fender
as a tall guy i sort of wish i had put it in the top of the fender
looked like a great location on sawhorses
shop air compressor timer
Old 09-08-2019, 06:20 PM   #14
slammed57
I like how you did the wood on top of the side bed supports, how did you secure the wood to the bed support?
slammed57 is offline   Reply With Quote
Old 09-08-2019, 07:20 PM   #15
mgchevyparts
Fords are different from Chevies, at least in 1940 they are. Plus it's back halfed. There's a 1"x1/8" steel frame work under the wood. Just pre drilled holes in the supports and screwed the wood down from below. I didn't want any bolt heads showing above.
Old 09-08-2019, 07:45 PM   #16
mgchevyparts
Although I'm mostly a Chevy guy I really like the looks of the 1940/41 Ford pick ups
Old 09-08-2019, 11:45 PM   #17
Johns327
Johns327's Avatar
I went around the backside of the fender. I’d recommend moving it up an inch or two to make the fuel angle a little steeper. This is a slow fill.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch.
Johns327 is offline   Reply With Quote
Old 09-09-2019, 09:09 PM   #18
MiraclePieCo
I've been getting questions about how I have my filler neck inside the cargo area. Again, THE FILLER NECK IS NOT INSIDE THE CAB - ONLY THE ACCESS DOOR! The filler neck is below the floor, the cap is sealed and the tank vented into a wheelwell. While I may look like I huff gas fumes all day, I assure you I don't.
Old 09-10-2019, 12:13 PM   #19
b-mac
b-mac's Avatar
You guys have seen this kit?
Old 09-10-2019, 01:57 PM   #20
_Ogre
_Ogre's Avatar
ran from dallas to nashville, with a guy that had this. he hated it, had to unload 80% of his truck each time he fueled. he had a bbc that sucked gas to boot, he fueled 3x to my one tank
Old 09-10-2019, 04:18 PM   #21
dsraven
here's mine. old fuel door from an scrap envoy. door was flat to start with. a little fun getting the shape on the fender and the perimeter ring cut from the donor.
Old 09-10-2019, 04:24 PM   #22
dsraven
hey ogre, did you use the stock spare tire carrier mounts or custom fab a new one. wondering the diameter of the tire you use as well. looks good. my spare tire mount is long gone but will fab something if I can't find a good used one. may not work with my box anyway. my tires will be 235/60r17, so 28.1" tall. hope the spare fits without hitting the cab.
I always thought your truck was a cool design, a truck with a trunk. cool.
Old 09-10-2019, 08:36 PM   #23
slammed57
Thanks so much bud. your bed wood came out very nice
Old 09-11-2019, 11:35 AM   #24
b-mac
b-mac's Avatar
I can understand that.
You could split the board at one of the cross-sills. You would have to do the whole bed length.
Old 09-11-2019, 11:42 AM   #25
dsraven
that bed filler on the green truck looks really showy, great for a low use unit I guess. very tiddly looking. my truck will be a daily driver if I ever get it done before I have to surrender my lic, haha. I plan to use the box for stuff so the fender mounted gas door is a must for me. besides, we get snow up here and it is one more way to get water in the tank when filling. sure looks good though.
