Old 05-24-2020, 10:34 AM   #1
ratman90
1972 C10 dome light removal?
PO installed a new dome light kit. Chrome base, clear lenses and all.
Looks nice. Went to install an LED bulb, and found the wires were wrapped around the end of the bulb amd then snapped in? Wth?
I want to remedy this and attach the wires to the housing correctly, but how does the housing come off? I see no screws?
If it helps, they also installed a cargo light that is powered off the dome light. No manual switch. Dome light comes on, so does the cargo light.
Errg!
1972 C10 LWB 2WD
307 4 speed
Rescued from Field July 2017
ratman90 is offline   Reply With Quote
Old 05-24-2020, 02:46 PM   #2
bigmac73
bigmac73's Avatar
Re: 1972 C10 dome light removal?
The chrome plastic base just pops in the truck holes. Pop it out and you can add wires on back of dome assembly.
I have thr cargo light option but i has a separate switch below the dome lighy
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 05-24-2020, 02:47 PM   #3
bigmac73
bigmac73's Avatar
i would use a small toggle switch to control the cargo light and re wire to fuse block
Mike
Old 05-24-2020, 03:07 PM   #4
ratman90
Ok cool. Big mac, I do not want to scratch paint.
Do I just get a plastic trim remover between the housing and steel of the cab and pry off?
1972 C10 LWB 2WD
307 4 speed
Old 05-26-2020, 06:20 PM   #5
bigmac73
bigmac73's Avatar
Yep u might be able to squeeze the side and pop it off
Mike
